Unlock Server
Old 12-31-2008, 07:46   #1 (permalink)
notgood's Avatar
Member: 355635
@InfinitySupport......
i have TAXCO TX60 come to me with hang problem, then i try to repair with infinity, try conect with APF get complete
this is the log
software version: 1.17
cable type: 1x12 (L12C)
platform: MT: MT6205, MT6217-MT6228, MT6230
searching adapter at COM8...
adapter found, version: 2000
pins: 12, plain
power cycles: 1
activation cycles: 7
power-off delay: 20
start Rx/Tx: 1/1
Loading configuration...
Initializing...
Press and HOLD phone Power button now !
detecting pins...
19200 fixed
CPU: MT6225
result: Rx:1 Tx:7
time required: 2 sec
Power On !
Then i try to format this phone...BUT software can't format this phone
this is the log
COM8 [VCP0] selected
module v2.73
Action: reset settings
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200 autodetect
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:9803:0002
Connecting, wait...
Release Power button now !
Phone detected, wait...
warning: can't read software version, probably unknown firmware
detecting structure #2...
0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18warning: wrong packet cs
19 20 21 22 23 24 25 26 27error: detection failed (28 tries), read flash and send to support
connection lost
error: operation failed !
Finished, time used: 7 sec
Remove/Install battery now !
here i do read full flash n eeprom for u to help me solve my problem i attc to rapid
http://rapidshare.com/files/17837790...racle.zip.html
sorry bad english
regards
notgood
Old 12-31-2008, 15:06   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Hello,
If phone can not be formatted in "safe" mode you need to make format in "complete" mode, but always make full flash backup before "complete" format !
The Following User Says Thank You to InfinitySupport For This Useful Post:
Page generated in 0.33766 seconds with 10 queries
