12-27-2008, 17:22 | #1 (permalink) |
Banned Join Date: Feb 2004 Location: Portharcourt,Nigeria
Member: 89584 Status: Offline Thanks Meter: 68 | please,infinity team zte a66 is not supported in ur software |
12-27-2008, 17:53 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | @sky_force71 You must think twice before make posts in future. Here is Infinity-Box support forum and your stupid advertizing message was deleted. |
12-28-2008, 11:29 | #4 (permalink) |
Member: 89584 Status: Offline Thanks Meter: 68 | COM5 [VCP0] selected module v1.58 Device: ZTE-A66 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! error: wrong boot answer #1: Release Power button now Boot Failed Finished, time used: 70 sec Remove/Install battery now ! it is not booting on a66.but works perfect on a61 |
12-29-2008, 07:38 | #6 (permalink) |
Member: 89584 Status: Offline Thanks Meter: 68 | [QUOTE=GOODNESS;4006594]COM5 [VCP0] selected module v1.58 Device: ZTE-A66 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! error: wrong boot answer #1: Release Power button now Boot Failed Finished, time used: 70 sec Remove/Install battery now ! this log is for a66 |
12-29-2008, 11:32 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Hello, Yes, I understand that it was communication problem. Please, post here A66 operation log (like A61) so we can check what is the problem. This means: if you had a good luck and your A66 phone was connected like A61, please, post here operation log when you have connected A66 like A61. This may helps to us to understand what is the difference in A66 "old hardware" and "A66 new hardware". |
12-29-2008, 16:02 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Hello, Do you have ordinary COM port cable (not box RJ45 cable) ? In some cases it was good results with ordinary COM port cable. Can you try to use ordinary COM port cable ? |
02-02-2009, 19:30 | #10 (permalink) | |
Freak Poster Join Date: Dec 2005 Location: Madagascar
Member: 207280 Status: Offline Thanks Meter: 15 | zte a66 Quote:
It is the same repport with a ordinary port com1 I have USPI V2 but zte a66 (a301, a68 New and v100) aren't boot with infinity software "Pana01_v1.61" to choose all models. I think that in future version "Pana01_v1.62" it will have to do. The SagDD is best for their. Best regards Josh | |
Infinity team still bleu 351x not supported | chiragp | Infinity-Box | 17 | 08-20-2010 15:13 |
infinity team why this phone not supported? | bavesore | Infinity-Box | 3 | 03-05-2010 15:00 |
ALAFATEL H5A is not supporting in spiderman box please add | azad4u | SpiderMan | 3 | 01-11-2010 04:32 |
Zte a66 still not supported | mohammed ako | Infinity-Box | 16 | 03-09-2009 09:46 |
