08-17-2007, 22:40 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: United States Age: 50
Member: 259133 Status: Offline Thanks Meter: 22 | motorola c139 tracfone v8.8.17 i talked via private message to infinyty help, but we didnt conclude this situation, i need help unlocking 87 motorola c139 tracfone, the versions are 8.8.17 and 8.5.17 well, what i have done till now is cut the track, some of them power on and most of them dont power after the track cut, i know that when they dont power on we are doing well, the ones that power on i have to remove cpu and remove a ball, i need the picture for those one, well, on the other hand when the phones dont power on i went to repair module, and select c139 ok checked soft restore, and without soft restore as well, when i hit to load repair data i see 2 files, i tried with both of them but when i hit write, the software ask me to push power button, but nothing happens, always the same no conection between phone and machine, besides i have done it in the normal mode, selected c139, and went to settins and checked repair mode, then what else i have to do, flash with main, lp, and flex, or what? cause i tried flashing but not conection anyway what else can i do please |
08-22-2007, 22:11 | #2 (permalink) |
Member: 259133 Status: Offline Thanks Meter: 22 | OK, i did it already, just used in conection method 4, and pushed the rj45 motorola t191 cable hard in the phone, it was not conecting due to the cable, i did it and flashed it with 1.0.24 main, flex and lp, selected in settings "repair mode" conection (cut track) and "soft restore" cutted track during flash, then flashed it, and ok eeeeeeeeeeeeeeeeeeverithing ok now, let me continue with the 86 pieces left, jajaja thank you very much infinity team |
08-23-2007, 11:40 | #3 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | some time r&d is more power full then any ready made answer.. now u see infinity is so power full tool just u need to know how to use.. good luck with ur all phones successfull results.. and enjoy infinity most power full and real solution base tool in market. |
08-23-2007, 19:04 | #5 (permalink) | |
Member: 259133 Status: Offline Thanks Meter: 22 | Quote:
thank you infinity team | |
08-23-2007, 20:43 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello rbisystems! just by pressing "unlock" button is possible to unlock only old firmware motorolas. New types require test point cut, and NEWEST can be done only by removing ball from leg N1. |
08-24-2007, 09:40 | #8 (permalink) | |
Freak Poster Join Date: Nov 2005 Location: Manila
Member: 198113 Status: Offline Sonork: 100.161124 Thanks Meter: 95 | Quote:
thank you best regard bogg7 | |
08-24-2007, 10:04 | #9 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! when you re-ball micro BGA IC- all its pins are covered by small balls. via this balls it is connected with PCB. you need to remove one Ball from leg N1 to disconnect it from PCB when it will be soldered back |
09-01-2007, 10:47 | #10 (permalink) | |
did anyone try this solution where is the link, thank you? | |
09-26-2007, 17:42 | #12 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! when you dedoldered MCU and reballed it- removing one ball is not a problem at all. Problem is to solder MCU back, but this is a question of skill... |
C139 convert problem s/w v8.8.17 cant connect | mobile_juice | Motorola ODM | 1 | 01-15-2010 09:06 |
C139 tracfone V9.2.17 | budaw | Motorola Hardware Repair | 0 | 04-09-2009 02:12 |
How can i unlocked my pon c139 trackfone v8.8.17? | mysterymanclone | Motorola ODM | 1 | 12-20-2008 06:49 |
c139 v8.8.17 Help to unlock | manyosa | Smart-Clip | 6 | 11-05-2007 14:56 |
c139 Trance Fone v8.8.17 unlock sucessfully but no network | roopvir | Infinity-Box | 7 | 03-29-2007 08:31 |
