01-24-2011, 19:15 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: cameroon
Member: 260658 Status: Offline Thanks Meter: 184 | Alcatel ot255 dead repair imei procedure: Loading data, wait... [Infinity Box] MModule v3.72 smart-card: connected S/N: 68AF:0116 Wait... Device: Alcatel-255X, 255A Done ==== [24/01/2011 13:55:07] ==== COM4 [VCP0] selected ==== [24/01/2011 13:57:21] ==== COM4 [VCP0] selected module v3.72 Device: Alcatel-255X, 255A Checking data, wait... advanced flash detection enabled Action: "repair imei" new imei: 351762042997395 ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:7C7B:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:2BEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.C4591 85C.[JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A_W08_36_SP 1_V34.BIN_D4C677EA].rpl ==================== New firmware found (v.3.72, database date: 23.12.2010): JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A_W08_36_SP 1_V34.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished TCL-ID detection... TCL-ID detection done device-id: C459185C rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A_W08_36_SP 1_V34.BIN project-id: MAUI.08A.W08.36.SP1.V34, EA77C6D4 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 96I provider: 255X-2ARGTE1 customization: CP96CMA1 customization: XP96CMA1 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35176204299739 flash: 01227E22202200:2BEA0000000000 Backup required data Done ====> Patch required data ... ............... pass #1 firmware remap[01]: 08000000 pass #2 firmware remap[01]: 08000000 ..... pass #3 firmware remap[01]: 08000000 ............................ Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 01227E22202200:2BEA0000000000 flash: 01227E22202200:2BEA0000000000 Write: imei flash: 01227E22202200:2BEA0000000000 flash: 01227E22202200:2BEA0000000000 Write: imei flash: 01227E22202200:2BEA0000000000 flash: 01227E22202200:2BEA0000000000 Write: imei sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected relocation table detected name table[00] #7000000 detected customization: CP96CMA1 customization name adjusted customization: CP96CMA1 customization name adjusted customization detected: CP96CMA1 customization: CP96CMA1 customization: XP96CMA1 error: can't calculate security area (sec info, cust), existing data will be used Check support area for updates ! security area (sec info, cust) calculation done security area (sec info, hash) calculation... version is not found in database: JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A_W08_36_SP 1_V34.BIN use default security area (sec info, hash) pattern max address is too big, should be recalculated: 08BF8000->087C1178 ..................security area (sec info, hash) detecting size... error: security area (sec info, hash) size is incorrect: 01C0 instead of 0374 Write Done ====> Finalization ... ffs formatting... flash: 01227E22202200:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-255X,255A_JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A _W08_36_SP1_V34__system_log_C459185C_D4C677EA_2011 0124-140239.B0X.bin Finished, time used: 4 min 57 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! UNLOCK PROCEDURE: ==== [24/01/2011 14:02:46] ==== COM4 [VCP0] selected module v3.72 Device: Alcatel-255X, 255A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:7C7B:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:2BEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.C4591 85C.[JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A_W08_36_SP 1_V34.BIN_D4C677EA].rpl ==================== New firmware found (v.3.72, database date: 23.12.2010): JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A_W08_36_SP 1_V34.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished TCL-ID detection... TCL-ID detection done device-id: C459185C rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A_W08_36_SP 1_V34.BIN project-id: MAUI.08A.W08.36.SP1.V34, EA77C6D4 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 96I provider: 255X-2ARGTE1 customization: CP96CMA1 customization: XP96CMA1 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XP96CMA1 customization name adjusted flash: 01227E22202200:2BEA0000000000 flash: 01227E22202200:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... version is not found in database: JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A_W08_36_SP 1_V34.BIN use default security area (sec info, hash) pattern max address is too big, should be recalculated: 08BF8000->087C1178 ..................security area (sec info, hash) detecting size... error: security area (sec info, hash) size is incorrect: 01C0 instead of 0374 file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-255X,255A__system_log_C459185C_D4C677EA_20110124-140517.B0X.bin Finished, time used: 2 min 28 sec Remove/Install battery now ! ==== C:\Program Files\InfinityBox\MModule\MModule.exe [24/01/2011 14:42:47] ==== web site: Infinity-Box - About Loading data, wait... [Infinity Box] MModule v3.72 smart-card: connected S/N: 68AF:0116 Wait... Device: Alcatel-255X, 255A Done Loading file v.05... 255A-2CRGDO3-968_XP96NT31_JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_ 08A_W08_36_SP1_V34_2010-07-20_En_Fr_Es_It_Pt.B0M.bin loaded usb bootloader (file) is absent rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A_W08_36_SP 1_V34.BIN project-id: MAUI.08A.W08.36.SP1.V34, C2CD0B3F code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 rom info structure: [protected] type (05), 1 record(s) TCL-ID is present file w/protection: startup code area #1 firmware date/time: 2010-07-20 21-23 hw1: JRD23_08A_HW hw2: 08A_JRD23_08A ==== [24/01/2011 14:44:06] ==== COM4 [VCP0] selected module v3.72 Device: Alcatel-255X, 255A Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware 255A-2CRGDO3-968_XP96NT31_JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_ 08A_W08_36_SP1_V34_2010-07-20_En_Fr_Es_It_Pt.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:7C7B:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:2BEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.C4591 85C.[JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A_W08_36_SP 1_V34.BIN_3F0BCDC2].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: C459185C rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A_W08_36_SP 1_V34.BIN project-id: MAUI.08A.W08.36.SP1.V34, C2CD0B3F code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 96I provider: 255X-2ARGTE1 customization: CP96CMA1 customization: XP96CMA1 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: disabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35176204299739 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... usb bootloader (file) is absent startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-255X,255A_JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A _W08_36_SP1_V34__system_log_C459185C_3F0BCDC2_2011 0124-144517.B0X.bin Area: Firmware flash: 01227E22202200:2BEA0000000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected relocation table detected name table[00] #7000000 detected customization: CP96NT31 customization name adjusted customization: CP96NT31 customization name adjusted customization detected: CP96NT31 customization: CP96NT31 flash: 01227E22202200:2BEA0000000000 flash: 01227E22202200:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 01227E22202200:2BEA0000000000 flash: 01227E22202200:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Write Done ====> Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-255X,255A_JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A _W08_36_SP1_V34__system_log_C459185C_3F0BCDC2_2011 0124-145133.B0X.bin Finished, time used: 7 min 7 sec Remove/Install battery now ! I DOWNLOAD NEW VERSION 3.73 AN REPEAT UNLOCK PROCEDURE, BUT PHONE STILL NO POWER UP NEED HELP PLEASE Last edited by InfinityHelp; 06-27-2020 at 10:18. Reason: legacy links removed |
01-26-2011, 00:07 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | 1. make full flash backup 2. send full flash backup file (or link) to [email protected] 3. send this file to [email protected] (exactly the same file as shown below): C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-255X,255A_JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A _W08_36_SP1_V34__system_log_C459185C_D4C677EA_2011 0124-140239.B0X.bin 4. flash phone with any firmware from support area what is the results ? |
01-26-2011, 19:35 | #3 (permalink) |
Member: 260658 Status: Offline Thanks Meter: 184 | Phone still dead Loading data, wait... [Infinity Box] MModule v3.73 smart-card: connected S/N: 68AF:0116 Wait... Device: Alcatel-255X, 255A Done Loading file v.05... 255X-901_XP92BJ30_JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_ 08A_W08_36_SP1_V34_2010-04-15_En_Cn_Cn.B0M.bin loaded usb bootloader (file) is absent rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A_W08_36_SP 1_V34.BIN project-id: MAUI.08A.W08.36.SP1.V34, E9F13744 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 rom info structure: [protected] type (05), 1 record(s) TCL-ID is present file w/protection: startup code area #1 firmware date/time: 2010-04-15 10-21 hw1: JRD23_08A_HW hw2: 08A_JRD23_08A ==== [24/01/2011 18:21:57] ==== COM83 [VCP0] selected COM83 not available Abort operation ? error: can't open COM83 module v3.73 COM9 ready COM10 ready COM1 ready COM83 not available Abort operation ? error: can't open COM83 ==== [24/01/2011 18:22:38] ==== COM83 [VCP0] selected module v3.73 Device: Alcatel-255X, 255A Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware 255X-901_XP92BJ30_JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_ 08A_W08_36_SP1_V34_2010-04-15_En_Cn_Cn.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:7C7B:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:2BEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.C4591 85C.[JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A_W08_36_SP 1_V34.BIN_3F0BCDC2].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: C459185C rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A_W08_36_SP 1_V34.BIN project-id: MAUI.08A.W08.36.SP1.V34, C2CD0B3F code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 901 customization: CP92BJ30 customization: XP92BJ30 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: disabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35176204299739 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... usb bootloader (file) is absent startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-255X,255A_JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A _W08_36_SP1_V34__system_log_C459185C_3F0BCDC2_2011 0124-182355.B0X.bin Area: Firmware flash: 01227E22202200:2BEA0000000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected relocation table detected name table[00] #7000000 detected customization: CP92BJ30 customization name adjusted customization: CP92BJ30 customization name adjusted customization detected: CP92BJ30 customization: CP92BJ30 flash: 01227E22202200:2BEA0000000000 flash: 01227E22202200:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 01227E22202200:2BEA0000000000 flash: 01227E22202200:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Write Done ====> Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-255X,255A_JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A _W08_36_SP1_V34__system_log_C459185C_3F0BCDC2_2011 0124-183615.B0X.bin Finished, time used: 13 min 17 sec Remove/Install battery now ! |
01-27-2011, 11:42 | #4 (permalink) | |
Member: 260658 Status: Offline Thanks Meter: 184 | Quote:
The Following User Says Thank You to nyakam For This Useful Post: |
01-28-2011, 12:01 | #6 (permalink) |
Member: 260658 Status: Offline Thanks Meter: 184 | @sir, here is Repair security log: COM83 [VCP0] selected module v3.73 Device: Alcatel-255X, 255A Checking data, wait... advanced flash detection enabled Action: repair security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:7C7B:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:2BEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.C4591 85C.[JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A_W08_36_SP 1_V34.BIN_4437F1E9].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: C459185C rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A_W08_36_SP 1_V34.BIN project-id: MAUI.08A.W08.36.SP1.V34, E9F13744 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 901 customization: CP92BJ30 customization: XP92BJ30 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected relocation table detected name table[00] #7000000 detected customization: CP92BJ30 customization name adjusted customization: CP92BJ30 customization name adjusted customization detected: CP92BJ30 customization: CP92BJ30 flash: 01227E22202200:2BEA0000000000 flash: 01227E22202200:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 01227E22202200:2BEA0000000000 flash: 01227E22202200:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35176204299739 flash: 01227E22202200:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E22202200:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-255X,255A_JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A _W08_36_SP1_V34__system_log_C459185C_4437F1E9_2011 0124-154623.B0X.bin Finished, time used: 2 min 58 sec Remove/Install battery now ! |
01-29-2011, 09:14 | #7 (permalink) |
No Life Poster Join Date: Oct 2006 Location: yaoundé (av kennedy)
Member: 361348 Status: Offline Thanks Meter: 635 | i tested all infinity flash for this fon without succes just read flash in another phone and if u av furious pack 8 activeted use it or sent me imei and provider |
02-12-2011, 19:46 | #8 (permalink) |
No Life Poster Join Date: Jun 2004 Location: algéria Age: 47
Member: 69250 Status: Offline Thanks Meter: 27 | hi infinty team i have one ot255x dead after unlock this the log: ==== [11/02/2011 09:02:24] ==== COM7 [VCP2] selected module v3.72 Device: Alcatel-255X, 255A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:4668:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: F:\Program Files\InfinityBox\MModule\backup_security\id.1460B 94F.[JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A_W08_36_SP 1_V34.BIN_1D8B7F4C].rpl ==================== New firmware found (v.3.72, database date: 13.01.2011): JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A_W08_36_SP 1_V34.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 1460B94F rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A_W08_36_SP 1_V34.BIN project-id: MAUI.08A.W08.36.SP1.V34, 4C7F8B1D code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 96E provider: 255X-2ANRFR1 customization: CP96CP85 customization: XP96CP85 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XP96CP85 customization name adjusted flash: 98000300000001:2BEA0000000000 flash: 98000300000001:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... version is not found in database: JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A_W08_36_SP 1_V34.BIN use default security area (sec info, hash) pattern max address is too big, should be recalculated: 08BF8000->087C0670 ..................security area (sec info, hash) detecting size... error: security area (sec info, hash) size is incorrect: 01C0 instead of 0374 file saved: F:\Program Files\InfinityBox\MModule\backup_security\Alcatel-255X,255A__system_log_1460B94F_1D8B7F4C_20110211-090538.B0X.bin Finished, time used: 2 min 53 sec. the flash in support can't relife my phone and fixing bug for that model thanks Yours Abdelouahab [email protected] Report Post Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiShare on FacebookTwitterStumble this Post! |
Repaired dead phone without backup | Prodigal | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-29-2011 11:26 |
HELP Dead 5130 v5.00 | N.Schmetz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 03-08-2011 04:51 |
help! Dead 5110 v5.30 | aklishin | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 04-04-2001 11:56 |
nokia 5110 dead | alpha | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-28-2001 11:59 |
6150 V5.20 WANTED --- DEAD OR ALIVE --- IT'S BETTER ALIVE ! ;))) | tcamilo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-19-1999 22:30 |
