05-22-2018, 23:15 | #1 (permalink) |
Freak Poster Join Date: Feb 2014 Location: Biafra
Member: 2128067 Status: Offline Thanks Meter: 16 | Infinix hot 5 (x559) after flash hang on xos chameleon logo Card found : S/N : XXXXXXXXX , v0136 Chinese Miracle II [MTK module] v 1.58 Scatter Load Ok , BaseBand : MT6580 , Project : rlk6580_weg_n , Storage : EMMC Files found : 9 , Set to Flash : 8 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : Infinix Device Model : Infinix-X559 Device CPU : MT6580 Device IntName : H8015 Device Version : 7.0 Device Compile : 8/18/2017 10:12:03 AM Device Project : X559-H8015AB-N-170818V107 Device ExtInfo : Infinix X559 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100464531324D420DEC12E00E7421 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM21E [eMMC] : FLASH_CID : 150100464531324D420DEC12E00E7421 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xB4341C361A76D7DD239EEFE9654E8757 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6580 , Project : rlk6580_weg_n , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3711 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000001C80000-0x0000000003320000 Erase : 0x00000000050A0000-0x000000039DCE0000 Flash Pre-Erase Done, time used : 00:00:02 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_rlk6580_weg_n.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0014 Use FLN Mode Processing : Flash Write Flash now : LK Image Flash Ok Flash now : BOOT Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : SECRO Image Flash Ok Flash now : SYSTEM Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USERDATA Image Flash Ok Flash Write Done, time used : 00:08:13 Processing : Verify Verify Passed : LK Verify Passed : BOOT Verify Passed : RECOVERY Verify Passed : LOGO Verify Passed : SECRO Verify Passed : SYSTEM Verify Passed : CACHE Verify Passed : USERDATA Data Verify Done, time used : 00:01:44 Update RomInfo done Done! Elapsed: 00:10:21 Reconnect Power/Cable! |
05-23-2018, 01:50 | #2 (permalink) |
No Life Poster Join Date: Mar 2018 Location: <...< Egypt >...>
Member: 2821459 Status: Offline Thanks Meter: 806 | Yea Its Normal Cuz U Should Try Backup from Phone First Befour Do Anything But Tell Me Your Phone X559 Or X559C And I will Give U firmware ... |
The Following User Says Thank You to Elgendi For This Useful Post: |
05-23-2018, 01:54 | #3 (permalink) |
Member: 2821459 Status: Offline Thanks Meter: 806 | https://mega.nz/#!IMRSQL7J!6RhotTwkR...IZW774DuO4z_wo pass:www.joker-soft.com Try this firmware U Problem Will Be Fixed.. |
07-09-2018, 18:45 | #4 (permalink) |
No Life Poster Join Date: May 2006 Location: Marrakech
Member: 282206 Status: Offline Thanks Meter: 102 | hello i have the same prolem after i full reset phone Start at : [09/07/2018 / 16:34:36] Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 67 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.2016-06-15.11:02 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100464536324D4203EBE3F0668477 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM26E [eMMC] : FLASH_CID : 150100464536324D4203EBE3F0668477 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x2A9B2E8CF89855EB7804DEDD9708267C INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:01:01 Reconnect Power/Cable! Finish at : [09/07/2018 / 16:35:38] i flash it with firmware joker-soft.com but still same problem thank you |
07-10-2018, 16:01 | #8 (permalink) | |
Member: 541591 Status: Online Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
What is current condition of phone? Stuck on logo or what? Br. Infinity Box Team | |
07-11-2018, 07:10 | #10 (permalink) |
Freak Poster Join Date: Apr 2012 Location: 9ja
Member: 1745682 Status: Offline Thanks Meter: 49 | Bro, just download the factory firmware and write don't waste ur time next time. That is how the phones are (infinix x559, x559c and tecno LA6). Back up file don't normally work on them even though u can copy and write successfully. |
