05-04-2016, 14:08 | #1 (permalink) |
Freak Poster Join Date: Apr 2007 Location: morocco
Member: 480799 Status: Offline Thanks Meter: 21 | infinix x510 dead after wrong flash i flash infinix x510 with wrong flash , now the phone is dead , i try to flash with the correct file it give me this error Operation : Flash [ v1.47 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 11 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100463832324D42003670FE77B2C1 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0xC40B0000 EMICFG_RET_FAILED CodeDefine : DA_DEVICE_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:20 Reconnect Power/Cable! how can i solve this problem tnx |
05-04-2016, 14:45 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Due DA report it shows about impossible to find DRAM. That is strange. Does device flashed completely first time? |
05-04-2016, 15:16 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Can advise just to try use some old SPFT version, like 152x or similar. But not sure about success result. Try charge battery completely and leave device without battery for a hour-two. |
05-04-2016, 16:44 | #6 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Init preloader also not help, because DRAM should be initialized first. Did you try old spft version as advised? What a result? Any error code? |
05-04-2016, 17:20 | #7 (permalink) |
Member: 480799 Status: Offline Thanks Meter: 21 | some problem Card found : S/N : 0A5A4586 , v0130 Chinese Miracle II [MTK module] v 1.44 Scatter Load Ok , BaseBand : MT6580 , Project : d5110_infinix , Storage : EMMC Files found : 9 , Set to Flash : 8 Ready to Flash! Operation : Flash [ v1.44 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 11 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100463832324D42003670FE77B2C1 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0xC40B0000 EMICFG_RET_FAILED Boot Error! Operation Failed Elapsed: 00:00:27 Reconnect Power/Cable! |
05-04-2016, 17:33 | #8 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | By SPFT I mean SP Flash Tool v152x or similar. Just to make sure about problem in HW or in FW. There is also chance about not correct FW for that HW version. Have you try make "Identify" without select FW? ( unselect FW in Flash Tab before try ) |
05-04-2016, 18:19 | #9 (permalink) |
Member: 480799 Status: Offline Thanks Meter: 21 | in SP Flash Tool v152 i have this error brom error :s_f_t_ENABLE_DRAM_FAIL (4032) i make read info this is log Card found : S/N : 0A5A4586 , v0130 Chinese Miracle II [MTK module] v 1.44 Operation : Check / Read Info [ v1.44 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 11 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100463832324D42003670FE77B2C1 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:14 Reconnect Power/Cable! |
07-15-2016, 17:43 | #10 (permalink) |
Junior Member Join Date: Aug 2015 Location: Cairo, Egypt
Member: 2440423 Status: Offline Sonork: dega Thanks Meter: 0 | i have same problem did you solve it bro 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Insert USB cable. In some cases Required Hold BootKey 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Waiting for USB Port... Set MTK USB Port (COM16) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6580 SW:0000 Ver: CA00 Downloading Boot8 ... ERR21002.00 Waiting for USB Port... Set MTK USB Port (COM16) Open Port Err: >>*** the Port be occupied. |
