08-03-2015, 18:59 | #1 (permalink) |
No Life Poster Join Date: Jan 2008 Location: NIGERIA
Member: 676315 Status: Offline Thanks Meter: 120 | infinix x551 privacy not done now dead Operation : Check / Read Info [ v1.24 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 38 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 15010052345A314D42022A83593291A9 DA Stat : v4.2 on BBID : 0x8A DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00BC Error : DA init Failed! Error code : 0x5 LErr : EMICFG_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:12 Reconnect Power/Cable! |
08-03-2015, 19:32 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Next time, before kill phones, try check logs and understand, what SW asking. In 99% cases - read log is enough to solve problem. CM2 not allow you flash this phone, because it have different HW. SPFT ignore all, and sure, it killed your phone. Seek now correct FW and repair phone. |
08-04-2015, 11:41 | #6 (permalink) |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | Hovatek Stock backup (MTK) for Infinix X551 - Download - 4shared - Hovatek Company check this is ur file |
08-04-2015, 19:23 | #12 (permalink) |
Member: 676315 Status: Offline Thanks Meter: 120 | cm2 always show error with this phone the log is on my 1st post and cm2 don't recognise the scatter file unless readed with cm2,please help on how to read in bin format to repair the phone and i don't understand the log you want me to post. |
08-04-2015, 19:32 | #13 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | CM2 NOT recognize scatter from this post? http://forum.gsmhosting.com/vbb/11203221-post6.html |
