Old 02-01-2016, 16:29   #1 (permalink)
Member: 167271
Thanks Meter: 4
Infinix x551 stuck in logo after flash
I try to use smart av option for X551 has virus , but after use it stuck in logo , Fortunately i read flash before i did that , so i reflash back , so it works agin , this device was 16G , 1G ram so i search i find flash file but after flash it stuck agin in logo , i tray many files but same problem , even reflash with the origenal file still same problem , so any idea ????
Sent from my iPhone using Tapatalk
Old 02-01-2016, 17:07   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Hello. Make FlashIc test. In Extra tab.
The Following User Says Thank You to JayDi For This Useful Post:
Old 02-02-2016, 13:00   #3 (permalink)
Member: 167271
Thanks Meter: 4
[Processing] FlashMemory Read-Write test
[eMMC] : [SAMSUNG] , BASX8 , 0x3A3E00000 , 14910 MiB
[eMMC] : CID : 15010051385853414206B470CA2C821D
[eMMC] : MODE : SQ-WR
[PASSED] : eMMC RW Check #1 Ok!
[eMMC] : MODE : RA-WR
[PASSED] : eMMC RW Check #2 Ok!
[eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed!
All Done!
Done!
Elapsed: 00:00:59
Reconnect Power/Cable!
Old 02-02-2016, 13:33   #4 (permalink)
JayDi's Avatar
Member: 462970
eMMC is Ok, Seems as problem now only in correct FlashFile.
Sned me also scatter from backup for check.
Old 02-02-2016, 15:21   #5 (permalink)
Member: 167271
Thanks Meter: 4
######################################-=INFINITY-BOX=-################################################## ####
# General Setting
####################################-=CHINESE MIRACLE=-################################################## ###
- general: MTK_PLATFORM_CFG
info:
- config_version: V1.1.2
platform: MT6592
project: ratech92_cwet_rlk_kk
storage: EMMC
boot_channel: MSDC_0
block_size: 0x20000
# Layout Setting
- partition_index: SYS0
partition_name: PRELOADER
file_name: preloader_ratech92_cwet_rlk_kk.bin
is_download: true
type: SV5_BL_BIN
linear_start_addr: 0x0
physical_start_addr: 0x0
partition_size: 0x40000
region: EMMC_BOOT_1
storage: HW_STORAGE_EMMC
boundary_check: true
is_reserved: false
operation_type: BOOTLOADERS
reserve: 0x00
- partition_index: SYS1
partition_name: MBR
file_name: MBR
is_download: true
type: NORMAL_ROM
partition_size: 0x80000
region: EMMC_USER
is_reserved: false
operation_type: UPDATE
reserve: 0x00
- partition_index: SYS2
partition_name: EBR1
file_name: EBR1
is_download: true
type: NORMAL_ROM
linear_start_addr: 0x80000
physical_start_addr: 0x80000
region: EMMC_USER
is_reserved: false
reserve: 0x00
- partition_index: SYS3
partition_name: PRO_INFO
file_name: NONE
is_download: false
type: NORMAL_ROM
linear_start_addr: 0x100000
physical_start_addr: 0x100000
partition_size: 0x300000
region: EMMC_USER
is_reserved: false
operation_type: PROTECTED
reserve: 0x00
- partition_index: SYS4
partition_name: NVRAM
file_name: NONE
is_download: false
type: NORMAL_ROM
linear_start_addr: 0x400000
physical_start_addr: 0x400000
partition_size: 0x500000
region: EMMC_USER
is_reserved: false
operation_type: BINREGION
reserve: 0x00
- partition_index: SYS5
partition_name: PROTECT_F
file_name: NONE
is_download: false
type: NORMAL_ROM
linear_start_addr: 0x900000
physical_start_addr: 0x900000
partition_size: 0xA00000
region: EMMC_USER
is_reserved: false
reserve: 0x00
- partition_index: SYS6
partition_name: PROTECT_S
file_name: NONE
is_download: false
type: NORMAL_ROM
linear_start_addr: 0x1300000
physical_start_addr: 0x1300000
region: EMMC_USER
is_reserved: false
reserve: 0x00
- partition_index: SYS7
partition_name: SECCFG
file_name: NONE
is_download: false
type: NORMAL_ROM
linear_start_addr: 0x1D00000
physical_start_addr: 0x1D00000
region: EMMC_USER
is_reserved: false
operation_type: INVISIBLE
reserve: 0x00
- partition_index: SYS8
partition_name: UBOOT
file_name: lk.bin
is_download: true
type: NORMAL_ROM
linear_start_addr: 0x1D40000
physical_start_addr: 0x1D40000
partition_size: 0x60000
region: EMMC_USER
is_reserved: false
reserve: 0x00
- partition_index: SYS9
partition_name: BOOTIMG
file_name: boot.img
is_download: true
type: NORMAL_ROM
linear_start_addr: 0x1DA0000
physical_start_addr: 0x1DA0000
region: EMMC_USER
is_reserved: false
reserve: 0x00
- partition_index: SYS10
partition_name: RECOVERY
file_name: recovery.img
is_download: true
type: NORMAL_ROM
linear_start_addr: 0x27A0000
physical_start_addr: 0x27A0000
region: EMMC_USER
is_reserved: false
reserve: 0x00
- partition_index: SYS11
partition_name: SEC_RO
file_name: secro.img
is_download: true
type: NORMAL_ROM
linear_start_addr: 0x31A0000
physical_start_addr: 0x31A0000
partition_size: 0x600000
region: EMMC_USER
is_reserved: false
reserve: 0x00
- partition_index: SYS12
partition_name: MISC
file_name: NONE
is_download: false
type: NORMAL_ROM
linear_start_addr: 0x37A0000
physical_start_addr: 0x37A0000
region: EMMC_USER
is_reserved: false
reserve: 0x00
- partition_index: SYS13
partition_name: LOGO
file_name: logo.bin
is_download: true
type: NORMAL_ROM
linear_start_addr: 0x3820000
physical_start_addr: 0x3820000
partition_size: 0x800000
region: EMMC_USER
is_reserved: false
reserve: 0x00
- partition_index: SYS14
partition_name: EXPDB
file_name: NONE
is_download: false
type: NORMAL_ROM
linear_start_addr: 0x4020000
physical_start_addr: 0x4020000
partition_size: 0xFE0000
region: EMMC_USER
is_reserved: false
reserve: 0x00
- partition_index: SYS15
partition_name: ANDROID
file_name: system.img
is_download: true
type: EXT4_IMG
linear_start_addr: 0x5000000
physical_start_addr: 0x5000000
partition_size: 0xA0000000
region: EMMC_USER
is_reserved: false
reserve: 0x00
- partition_index: SYS16
partition_name: CACHE
file_name: cache.img
is_download: true
type: EXT4_IMG
linear_start_addr: 0xA5000000
physical_start_addr: 0xA5000000
partition_size: 0x19000000
region: EMMC_USER
is_reserved: false
reserve: 0x00
- partition_index: SYS17
partition_name: USRDATA
file_name: userdata.img
is_download: true
type: EXT4_IMG
linear_start_addr: 0xBE000000
physical_start_addr: 0xBE000000
partition_size: 0x2E4900000
region: EMMC_USER
is_reserved: false
reserve: 0x00
- partition_index: SYS18
partition_name: BMTPOOL
file_name: NONE
is_download: false
type: NORMAL_ROM
linear_start_addr: 0xFFFF00A8
physical_start_addr: 0xFFFF00A8
partition_size: 0x1500000
region: EMMC_USER
boundary_check: false
is_reserved: true
operation_type: RESERVED
reserve: 0x00
Old 02-02-2016, 22:51   #6 (permalink)
Member: 167271
Thanks Meter: 4
Old 02-03-2016, 08:18   #7 (permalink)
JayDi's Avatar
Member: 462970
It seems as Ok.
Did you try make "Repair ExtData"?
Old 02-03-2016, 13:04   #8 (permalink)
Member: 167271
Thanks Meter: 4
It seems as Ok.
still same , so i try to flash with :
[Hovatek] Stock backup (MTK) for Infinix X551 (1GB)
now it open no display on screen !!!!!!!!!!!
Page generated in 0.20127 seconds with 8 queries
