Old 08-19-2018, 18:42   #1 (permalink)
Member: 2521913
Thanks Meter: 197
Infinix x553 qullcomm imei repair done and read write qcn
Wait for phone...
Device Found!
Initialize ...
DiagMode initialized!
MSMHW : 000091B0
MODHW : 00001011
BUILD : MPSS.DPM.2.0.2.c1.20-00005-M8936FAAAANUZM-1
RTIME : Mar 10 201618:49:04
BTIME : Jan 07 201622:00:00
DEVST : FAAAANUZ
xQCN details :
IMEI [1] : 356603072467245
IMEI [2] : 356603072467245
BTID : F1F596D144A4
WiFi : A444D196F5F2
Writing NVRAM data from XQCN image ...
Writing NV Items...
Writing SIM1 NV Items...
Writing SIM2 NV Items...
Writing RFNV...
Writing Provisioning Item Files...
Write done! Reboot device, if it not restart!
Hint : Factory Reset is required to finish process completely!
Done!
Elapsed: 00:00:22
Reconnect Power/Cable!
1. Enable DiagInterface on device [ by Code, Root or other way ]
2. Make sure DiagDrivers installed and work correct
Wait for phone...
Device Found!
Initialize ...
MSMHW : 000091B0
MODHW : 00001011
DEVST : FAAAANUZ
Update IMEI[1] : 352345678********
Record update Ok!
Update IMEI[2] : 356886098********
Record update Ok!
Hint : QCN write and Factory Reset is required to finish process completely!
Done!
The Following 3 Users Say Thank You to Alameeen For This Useful Post:
Old 08-19-2018, 21:01   #2 (permalink)
Member: 2500215
Thanks Meter: 230
How did you enable diag. Very important
Old 08-19-2018, 22:15   #3 (permalink)
Yusuf Lawal's Avatar
Member: 1677653
Thanks Meter: 1,877
Originally Posted by Alameeen View Post
Wait for phone...
Device Found!
Initialize ...
MSMHW : 000091B0
MODHW : 00001011
DEVST : FAAAANUZ
xQCN details :
BTID : F1F596D144A4
WiFi : A444D196F5F2
Writing NV Items...
Writing RFNV...
Done!
Elapsed: 00:00:22
Wait for phone...
Device Found!
Initialize ...
MSMHW : 000091B0
MODHW : 00001011
DEVST : FAAAANUZ
Record update Ok!
Record update Ok!
Done!
next time post full log.
Old 08-19-2018, 23:53   #4 (permalink)
Member: 2521913
Thanks Meter: 197
It's long process bros by super su
Old 10-22-2018, 11:01   #5 (permalink)
Member: 83123
Thanks Meter: 8
@Alameeen
Would you mind share the QCN file please ?... Thanks
Old 10-24-2018, 17:32   #6 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,296
Dear Sirs,
If you have good flash files and if you want to share it with other users please use IOS File Uploader Tool
Please do not upload password protected or damaged files, all of them will be deleted after upload.
Thank you !
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 10-25-2018, 00:57   #7 (permalink)
Member: 2521913
Thanks Meter: 197
Originally Posted by tian View Post
@Alameeen
Yes I will help you pm me
Old 03-19-2019, 18:54   #8 (permalink)
Member: 2553465
Thanks Meter: 8
Card found :
Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16
Operation : Read QCN (NVM) [ v1.16 ]
Wait for phone...
BREAK : Device not found!
HINT : Check cable, connection and drivers!
Wait for phone...
Operation : Write Security [ v1.16 ]
Wait for phone...
Wait for phone...
Wait for phone...
Device Found!
Initialize ...
MSMHW : 000091B0
MODHW : 00001011
BUILD : MPSS.DPM.2.0.2.c1-00081-M8936FAAAANUZM-1
RTIME : Sep 22 201519:02:05
BTIME : Aug 24 201502:00:00
DEVST : FAAAANUZ
Reading NVRAM data in XQCN format ...
Reading NV Items...
Reading NV Items SIM1...
Reading NV Items SIM2...
Reading RFNV...
Reading Provisioning Item Files...
Reading Feature_Mask...
Saved as : C:\InfinityBox\CM2QLM\Backup\QCN\000091B0__MPSS.DP M.2.0.2.c1-00081-M8936FAAAANUZM-1.xqcn
Read Done!
Done!
Elapsed: 00:00:50
Wait for phone...
Device Found!
Initialize ...
MSMHW : 000091B0
MODHW : 00001011
DEVST : FAAAANUZ
Update IMEI[1] : 35365707016****
Record update Ok!
Update IMEI[2] : 35365707516****
Record update Ok!
Done!
Elapsed: 00:00:05
Operation : Write QCN (NVM) [ v1.16 ]
Wait for phone...
Device Found!
Initialize ...
MSMHW : 000091B0
MODHW : 00001011
DEVST : FAAAANUZ
xQCN details :
IMEI [1] : 864580056533579
IMEI [2] : 864580056533579
BTID : B566DF731454
WiFi : 541473DF64AD
Writing NV Items...
Writing RFNV...
Done!
Elapsed: 00:00:34
Operation : Reset Settings [ v1.16 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_I : SnapDragon 415 [MSM8929]
ID_BLOCK_S : 0401970E
ID_BLOCK_L : 9B6D07FF5EC4F1FCAB80705D9AE17159
ID_BLOCK_L : D8AB15B4B9289213B6014A83816C7A41
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8929 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ]
ExtInfo : 0x00004000/00004000/00001000/00001000/00000200
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:43
HOW TO ENABLE DIAG VERY IMPORTANT
Enable Diag Mode: To write QCN file, you need to activate diag mode.
type *#*#13491#*#* or ####8789# on dial screen then click activate and if the code ...
The Following 2 Users Say Thank You to hassanzaheer For This Useful Post:
Old 03-20-2019, 07:31   #9 (permalink)
Member: 2553465
Thanks Meter: 8
Its easy bro, just turn on adb and root with kingo root tool , u r done
The Following User Says Thank You to hassanzaheer For This Useful Post:
Page generated in 0.32002 seconds with 7 queries
