Old 09-15-2019, 17:24   #1 (permalink)
safina gsm's Avatar
Member: 2906511
Thanks Meter: 136
INFINIX X55514D dead only show mediatek usb com ....how to make it alive?
here is log from cm2mt2
Created by Infinity-Box (c) 2018
Chinese Miracle II : MediaTek Service Module
Device Info file : _Android_info.txt
Patch Level : O11019
Display ID : X5514-H395AD-O-180608V144
Ver. CodeName : REL
Ver. Release : 8.1.0
Sec. Patch : 2018-05-05
Build Time : 1528461786
Product Brand : Infinix
Product Name : H395
Product Device : Infinix-X5514
Product Model : Infinix X5514D
Product Manfct : INFINIX MOBILITY LIMITED
Product Board : x5514d_h395
Board Platform : mt6739
Preloader [HW DEV] Info :
EMI : DEV :
EMI : SRC :
EMI : CNT : 0000
Operation : Write Flash [ v2.06 ]
Repartition : Enabled
Flash Verify : Disabled
Reg.Pre-Erase : Enabled
Verify HW/SW : Enabled
SData Backup : Disabled
Safe UserData : Disabled
Files :18
[FL] : Set : preloader_x5514d_h395.bin
[FL] : Set : recovery.img
[FL] : Set : md1rom.img
[FL] : Set : md1dsp.img
[FL] : Set : spmfw.img
[FL] : Set : mcupmfw.img
[FL] : Set : lk.bin
[FL] : Set : lk.bin
[FL] : Set : loader_ext.img
[FL] : Set : boot.img
[FL] : Set : logo.bin
[FL] : Set : odmdtbo.img
[FL] : Set : tz.img
[FL] : Set : tz.img
[FL] : Set : system.img
[FL] : Set : cache.img
[FL] : Set : userdata.img
[FL] : Total size : 0x7C680774 [ 1.94 GB ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port (COM30)
MODE : BOOTROM
PORT : 30
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x000000E5
BROM : SecMode : SBC+SDA+ARB
BROM : BOOTROM
MODE : INFINIX : SECURE_BASE | Manual : Enabled
BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 V0: 0000 0000 [0001]
BROM : SOCID : DD88D28162944535A531096DB3BA2F7F77D575734241901C95 DCFAE7602D4F32
BROM : SLA
BROM : SLA Passed!
BROM : SLA CHLNG not used
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6739
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DA : EXT_RAM NOT initialized!
EMI : DEV : MT6739
EMI : SRC : preloader_x5514d_h395.bin
EMI : CNT : 0004
EMI : [00] : eMCP : eMMC+LP/DDR3 , ID : 150100514536334D42 : VEN : SAMSUNG | DEV : QE63MB : RAM : [ 2.00 GB ]
EMI : [01] : eMCP : eMMC+LP/DDR3 , ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3.00 GB ]
EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 150100464536324D42 : VEN : SAMSUNG | DEV : FE62MB : RAM : [ 1.00 GB ]
EMI : [03] : eMCP : eMMC+LP/DDR3 , ID : 700100454841434541 : VEN : KINGSTON | DEV : EHACEA : RAM : [ 2.00 GB ]
EMI : Init EMI from PRELOADER
EMI : EXT_RAM CFG Passed!
DA : BOOT to 2nd DA ...
DA : BOOT 2ND DA FAILED!
ERR : 0xC0070004
ERR : DA_HASH_MISMATCH
Error : Fail to init protocol!
Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation!
Reconnect Power/Cable!
Old 09-15-2019, 21:00   #2 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 2,102
this phone have ARB (anti rollback) security protection and cant be downgrade to old version
you have used X5514-H395AD-O-180608V144 and may be your phone have new version instaled for that you need flash newest version like :
X5514-H395AD-O-190225V223
and you can see in your log :
EMI : DEV :
EMI : SRC :
EMI : CNT : 0000
may be you have faulty preloader in your selected firmware
and if you have dead mobile and need to write preloader you need get auth file from infinity support
Old 09-16-2019, 18:16   #3 (permalink)
safina gsm's Avatar
Member: 2906511
Thanks Meter: 136
thank you for your reply but the main Problem is here
ERR : 0xC0070004
do you have any idea?
Old 09-17-2019, 18:18   #4 (permalink)
safina gsm's Avatar
Member: 2906511
Thanks Meter: 136
i have tried all operations in this phone such as identify and flash
but it can't do anything well it always give that error:
ERR : 0xC0070004
can anyone give me some advices?
Old 09-17-2019, 19:31   #5 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 2,102
ERR : 0xC0070004
you can use :
MTK_AllInOne_DA.bin from boot\0_base\BASE_v1912
but you need select auth file alredy in infinity file support at
Tecno-Infinix-Itel-Villaon-Spice-Oraimo-Dollyphin.7z
The Following User Says Thank You to rebainoor For This Useful Post:
Old 09-20-2019, 16:52   #6 (permalink)
safina gsm's Avatar
Member: 2906511
Thanks Meter: 136
you can use :
thank you for reply i'll post result soon
Page generated in 0.17117 seconds with 8 queries
