07-15-2018, 18:04 | #1 (permalink) |
No Life Poster Join Date: Sep 2013 Location: The Hell Age: 31
Member: 2033150 Status: Offline Thanks Meter: 624 | infinix X573B Qcomm CPU read info, FRP Erase Done :: you need to use edl pinout Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... BREAK : Device not found! HINT : Check cable, connection and drivers! Reconnect Power/Cable! Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 430 [MSM8937] ID_BLOCK_S : 813B3D27 ID_BLOCK_L : BC443ED877E3E81BC4B95B4483DE5676 ID_BLOCK_L : 166DD37A7FE648DDF03F90495BAA4487 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000E8F800000 [ eMMC 64 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RH64MB Boot Ok! Brand : Infinix ProdName : QL1668 ProdModel : Infinix X573 Device : Infinix-X573 AndroidVer: 8.0.0 Manufact. : INFINIX MOBILITY LIMITED SysPatch : OPR1.170623.032 DevComTime: 1/4/2018 4:41:28 PM QLMxPRJ : X573-QL1668DEF-O-IN-20180105V19 USERData : NORMAL GCSec : NORMAL Done! Elapsed: 00:00:12 Reconnect Power/Cable! Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 430 [MSM8937] ID_BLOCK_S : 813B3D27 ID_BLOCK_L : BC443ED877E3E81BC4B95B4483DE5676 ID_BLOCK_L : 166DD37A7FE648DDF03F90495BAA4487 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000E8F800000 [ eMMC 64 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RH64MB Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:42 Reconnect Power/Cable! Last edited by xx0o0xx1; 07-19-2018 at 01:06. |
The Following 5 Users Say Thank You to xx0o0xx1 For This Useful Post: |
07-15-2018, 18:15 | #3 (permalink) |
Member: 2033150 Status: Offline Thanks Meter: 624 | Edl mode.. PinOut Test Point..... Sent from my SM-N920C using Tapatalk Last edited by xx0o0xx1; 07-16-2018 at 14:34. |
The Following 8 Users Say Thank You to xx0o0xx1 For This Useful Post: |
07-15-2018, 18:23 | #4 (permalink) |
Member: 2033150 Status: Offline Thanks Meter: 624 | Operation : Flash [ v1.16 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... BREAK : Device not found! HINT : Check cable, connection and drivers! Reconnect Power/Cable! Operation : Flash [ v1.16 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... BREAK : Device not found! HINT : Check cable, connection and drivers! Reconnect Power/Cable! Operation : Flash [ v1.16 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 430 [MSM8937] ID_BLOCK_S : 813B3D27 ID_BLOCK_L : BC443ED877E3E81BC4B95B4483DE5676 ID_BLOCK_L : 166DD37A7FE648DDF03F90495BAA4487 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000E8F800000 [ eMMC 64 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RH64MB Boot Ok! Flash Chain : 146 Flashing now Flashing : NON-HLOS.bin Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : tz.mbn Flashing : devcfg.mbn Flashing : devcfg.mbn Flashing : adspso.bin Flashing : fsall_image.tar.gz.mbn.img Flashing : emmc_appsboot.mbn Flashing : emmc_appsboot.mbn Flashing : boot.img Flashing : recovery.img Flashing : devinfo.bin Flashing : persist_1.img Flashing : config.bin Flashing : mdtp.img Flashing : cmnlib_30.mbn Flashing : cmnlib_30.mbn Flashing : cmnlib64_30.mbn Flashing : cmnlib64_30.mbn Flashing : keymaster64.mbn Flashing : keymaster64.mbn Flashing : oem.bin Flashing : cache_1.img Flashing : cache_2.img Flashing : cache_3.img Flashing : splash.img Flashing : vendor_1.img Flashing : vendor_2.img Flashing : vendor_3.img Flashing : vendor_4.img Flashing : vendor_5.img Flashing : vendor_6.img Flashing : vendor_7.img Flashing : vendor_8.img Flashing : vendor_9.img Flashing : vendor_10.img Flashing : vendor_11.img Flashing : vendor_12.img Flashing : vendor_13.img Flashing : system_1.img Flashing : system_2.img Flashing : system_3.img Flashing : system_4.img Flashing : system_5.img Flashing : system_6.img Flashing : system_7.img Flashing : system_8.img Flashing : system_9.img Flashing : system_10.img Flashing : system_11.img Flashing : system_12.img Flashing : system_13.img Flashing : system_14.img Flashing : system_15.img Flashing : system_16.img Flashing : system_17.img Flashing : system_18.img Flashing : system_19.img Flashing : system_20.img Flashing : system_21.img Flashing : system_22.img Flashing : system_23.img Flashing : system_24.img Flashing : system_25.img Flashing : system_26.img Flashing : system_27.img Flashing : system_28.img Flashing : system_29.img Flashing : system_30.img Flashing : system_31.img Flashing : system_32.img Flashing : system_33.img Flashing : system_34.img Flashing : system_35.img Flashing : system_36.img Flashing : system_37.img Flashing : system_38.img Flashing : system_39.img Flashing : system_40.img Flashing : system_41.img Flashing : system_42.img Flashing : system_43.img Flashing : system_44.img Flashing : system_45.img Flashing : system_46.img Flashing : system_47.img Flashing : userdata_1.img Flashing : userdata_2.img Flashing : userdata_3.img Flashing : userdata_4.img Flashing : userdata_5.img Flashing : userdata_6.img Flashing : userdata_7.img Flashing : userdata_8.img Flashing : userdata_9.img Flashing : userdata_10.img Flashing : userdata_11.img Flashing : userdata_12.img Flashing : userdata_13.img Flashing : userdata_14.img Flashing : userdata_15.img Flashing : userdata_16.img Flashing : userdata_17.img Flashing : userdata_18.img Flashing : userdata_19.img Flashing : userdata_20.img Flashing : userdata_21.img Flashing : userdata_22.img Flashing : userdata_23.img Flashing : userdata_24.img Flashing : userdata_25.img Flashing : userdata_26.img Flashing : userdata_27.img Flashing : userdata_28.img Flashing : userdata_29.img Flashing : userdata_30.img Flashing : userdata_31.img Flashing : userdata_32.img Flashing : userdata_33.img Flashing : userdata_34.img Flashing : userdata_35.img Flashing : gpt_main0.bin Flashing : gpt_backup0.bin Flash sequence completed! Applying patches for storage # 0 Records : 26 Patch sequence completed! BootConfig set to 0x00 Flashing done! Done! Elapsed: 00:03:47 Reconnect Power/Cable! Last edited by xx0o0xx1; 07-19-2018 at 01:05. |
The Following 2 Users Say Thank You to xx0o0xx1 For This Useful Post: |
07-16-2018, 01:26 | #6 (permalink) |
Member: 2033150 Status: Offline Thanks Meter: 624 | The problem is if u flashed this device it will cause a problem of MISSING apps and settings all firmware files . it's like a board firmware ,, nothing else even though i could've fetch the system file and unpacked it and all libs and files are exists in the PACKAGE but that still useless ,, some kind of customization or hidden features are missing ... trying to give it a last chance and will feed back here hope if i can solve this and then it will be EXCLUSIVE for infinity team . ----- Devx |
07-16-2018, 11:19 | #8 (permalink) |
Member: 2033150 Status: Offline Thanks Meter: 624 | As i promised, Solution will be exclusively for cm2 users, so anyone needs the file, just post read info log ofc using cm2qlm tool. And file will be sending to their pm. I'm very close to fix imei's either. And that's gonna be a Mega thread for infinity users.. P.s : the reason I'm restricted about the f.w is i struggled two days without sleeping to find a solution and i can't just give it to all.. Best regards ----- Devx Sent from my SM-N920C using Tapatalk |
07-16-2018, 20:17 | #11 (permalink) |
Member: 2033150 Status: Offline Thanks Meter: 624 | World's first imei repair x573b Operation : Write Security [ v1.16 ] NO ROOT REQUIRED!!! 1. Enable DiagInterface on device [ by Code, Root or other way ] 2. Make sure DiagDrivers installed and work correct Wait for phone... Device Found! Initialize ... DiagMode initialized! MSMHW : 000004F0 MODHW : 0000100C BUILD : MPSS.JO.3.0-00398-8937_GENNS_PACK-1.126887.1 RTIME : Jan 5 201801:01:29 BTIME : Nov 30 201723:00:00 DEVST : 8937.gen Update IMEI[1] : 35924588XXXXXX Record update Ok! Update IMEI[2] : 35924588XXXXXX Record update Ok! Write done! Reboot device, if it not restart! Hint : QCN write and Factory Reset is required to finish process completely! Done! Elapsed: 00:00:03 ---- Operation : Read QCN (NVM) [ v1.16 ] 1. Enable DiagInterface on device [ by Code, Root or other way ] 2. Make sure DiagDrivers installed and work correct Wait for phone... Device Found! Initialize ... DiagMode initialized! MSMHW : 000004F0 MODHW : 0000100C BUILD : MPSS.JO.3.0-00398-8937_GENNS_PACK-1.126887.1 RTIME : Jan 5 201801:01:29 BTIME : Nov 30 201723:00:00 DEVST : 8937.gen Reading NVRAM data in XQCN format ... Reading NV Items... Reading NV Items SIM1... Reading NV Items SIM2... Reading RFNV... Reading Provisioning Item Files... Reading Feature_Mask... Saved as : c:\infinitybox\cm2qlm\Backup\QCN\000004F0__MPSS.JO .3.0-00398-8937_GENNS_PACK-1.126887.1.xqcn ---- Devx_PASSAL Last edited by xx0o0xx1; 07-16-2018 at 20:37. |
The Following 3 Users Say Thank You to xx0o0xx1 For This Useful Post: |
07-16-2018, 20:30 | #12 (permalink) |
Member: 2033150 Status: Offline Thanks Meter: 624 | Operation : EDL Security Operation [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 430 [MSM8937] ID_BLOCK_S : 813B3D27 ID_BLOCK_L : BC443ED877E3E81BC4B95B4483DE5676 ID_BLOCK_L : 166DD37A7FE648DDF03F90495BAA4487 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000E8F800000 [ eMMC 64 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RH64MB Boot Ok! Backup Security Partitions Backup : FSG Backup : MODEMST1 Backup : MODEMST2 Backup saved to : c:\infinitybox\cm2qlm\Backup\MSM8937_[0004F0E1]_813B3D27_SEC\ |
07-16-2018, 20:32 | #13 (permalink) |
Member: 2033150 Status: Offline Thanks Meter: 624 | Note : For other world's first etc.. now wondering , can the other world's first does this ....??? The power is inside your brain , the way you are making ur brain works and infinity tools are amazing .... |
The Following User Says Thank You to xx0o0xx1 For This Useful Post: |
