04-16-2019, 09:19 | #1 (permalink) |
No Life Poster Join Date: Sep 2008 Location: Bohicon (Rep of Benin)
Member: 862014 Status: Offline Sonork: 100.1608307 Thanks Meter: 64 | infinix x624b dead after flash after flash my infinix x624b which hang on logo by the factory file X624B-H8026IJK-O-190201V201 with cm2mt2, the phone dead. Need help for know what option can reviver it thk |
04-16-2019, 13:47 | #4 (permalink) |
Member: 862014 Status: Offline Sonork: 100.1608307 Thanks Meter: 64 | thi is the log Reconnect Power/Cable! Operation : Write Flash [ v2.05 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Files :15 [FL] : Set : preloader_x624_h8025.bin [FL] : Set : lk-sign.img [FL] : Set : lk-sign.img [FL] : Set : boot-sign.img [FL] : Set : recovery-sign.img [FL] : Set : logo-sign.bin [FL] : Set : odmdtbo-sign.img [FL] : Set : vendor-sign.img [FL] : Set : tkv.img [FL] : Set : tee-sign.img [FL] : Set : tee-sign.img [FL] : Set : secro-sign.img [FL] : Set : system-sign.img [FL] : Set : cache-sign.img [FL] : Set : userdata-sign.img [FL] : Total size : 0x9D3A2EE4 [ 2,46 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM4) MODE : PRELOADER PORT PORT : 4 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : TECNO : BASE_SECURE\InfinixX624b DA | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_x624b_SP.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 484A0190613447420022A432E5926111 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A484247346132A42200116192E5 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HBG4a2 EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x747C00000 [ 29,12 GB ] SRAM: 0x00020000 [ 128,00 KB ] DRAM: 0x80000000 [ 2,00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 5B09D5CF27D02BFDDE09A2902D7EF166 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! SEC_DL : True (CUST) SEC_DL : SECURE USB DL ENABLED SEC_ID : 0x63616334633434326462376361623562 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000000080000 Erase : 0x0000000004C80000 : 0x000000013BB80000 [FL] : RePartition [FL] : RePartition Ok! SecInit : LK SecInit : LK2 SecInit : BOOT SecInit : RECOVERY SecInit : LOGO SecInit : ODMDTBO SecInit : VENDOR SecInit : TEE1 SecInit : TEE2 SecInit : SECRO SecInit : SYSTEM SecInit : CACHE SecInit : USERDATA [FL] : Flashing now ... Write : PRELOADER Update bootloader code ... Update bootloader Ok! Write : LK Write : LK2 Write : BOOT Write : RECOVERY Write : LOGO Write : ODMDTBO Write : VENDOR Write : TKV Write : TEE1 Write : TEE2 Write : SECRO Write : SYSTEM Write : CACHE Write : USERDATA SEC_DL : WRITE INFO : OK SEC_DL : True (CUST) SEC_DL : SECURE USB DL ENABLED SEC_ID : 0x63616334633434326462376361623562 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing finished! Done! Elapsed: 00:04:02 Reconnect Power/Cable! |
04-16-2019, 14:48 | #5 (permalink) |
No Life Poster Join Date: Feb 2018 Location: Nigeria
Member: 2812901 Status: Offline Thanks Meter: 493 | use factory sign firmware and download auth from support, latest da post from support which have both. http://forum.gsmhosting.com/vbb/f296...ution-2588894/ |
04-16-2019, 15:46 | #6 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,102 | http://forum.gsmhosting.com/vbb/f296...ution-2588894/ after this post you will never fear to kill your tecno or infinix or itel brands with CM2MT2 always pro solutions |
04-16-2019, 16:09 | #7 (permalink) |
Member: 231728 Status: Offline Thanks Meter: 2,102 | How to find the correct software update for your device (infinix) -Model number: must be matched. -Hardware version: must be matched. -Region mark: must be matched if there is a mark here. -Assembled in the local factory: must be matched if there is a mark here. -Android version: update any version which you prefer ( Software upgrade can be done through T-card update, Downgrade must be done with Flash version and Flash tool) |
The Following User Says Thank You to rebainoor For This Useful Post: |
04-18-2019, 08:35 | #8 (permalink) |
Member: 862014 Status: Offline Sonork: 100.1608307 Thanks Meter: 64 | thk for the answer but: what is auth files? and what is the diference between auth files and DA file? and why infinity team can t to show one easily link for downloqd it ifit too important for phone reviver. thk |
04-18-2019, 11:58 | #10 (permalink) |
Member: 2812901 Status: Offline Thanks Meter: 493 | There is link to download it but you must login with your infinity online service (IOS). where you can download 40 file if you have dongle active or download only 1 if your dongle is expired. |
