02-12-2024, 10:24 | #1 (permalink) |
No Life Poster Join Date: Apr 2014 Location: west java
Member: 2162000 Status: Offline Sonork: 100.1670061 Thanks Meter: 205 | infinix x6515 frp failed [DONE] then i use testpoint mode here log Code: Operation: Identify Device [ v2.52 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Mode: FLASH Port: Both [ B + P ] [+] High-Speed [+] Auto-EMI [+] FireFly-Over-DA extended protocol [-] Local SLA [-] Force BROM Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port_V1633 (COM4) MODE [0]: BOOTROM; PORT: 4 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] MEID: FC9CCD741A057DB46F617ED477E97A04 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: F41DAA46F04DEEEB0AE7C7B30079991052CFD7784376D823B193902C2F154BEA SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok FF: Looking for EMI Not Found SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 AGENT: MANUAL: Infinix: SEC_NEW [c7992f8b] C:\InfinityBox\CM2MT2\boot\Infinix\SEC_NEW\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found: MT6761; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: F401224152563131581330760FEF7AB3 crc Ok Ven: Biwin OEM: 290 ID: 415256313158 [ARV11X] PRV: 0x13 SNN: 813043695 [0x30760FEF] MM/YY: 7/2023 EMI[1]: Init via internal database EMI: INFINITY PRELOADER_INFINITY_1 with 8 memory type(s) Push EMI... Setup EMI parameters fail [ABORT] EMI: 1 => 2 Device EMI settings has been updated Now connect device again with the same operation! Another way - use preloader file <a href="https://infinity-box.com/?r=100233">Read manual</a> Done: 00:01:10 Reconnect Power/Cable now |
The Following User Says Thank You to solusi hp For This Useful Post: |
02-12-2024, 10:53 | #2 (permalink) |
No Life Poster Join Date: Nov 2008 Location: RVIII
Member: 890926 Status: Online Thanks Meter: 2,054 | Choose this loader or newer, try with TP, Code: AGENT: Infinix: 2023-05 | Manual: Off Br, xerraco |
The Following User Says Thank You to xerraco For This Useful Post: |
02-12-2024, 15:13 | #3 (permalink) | |
Download backup file for your device https://infinity-box.com/?r=100215 Unpack it, preloader is there Use preloader file for your model like here https://forum.infinity-box.com/viewtopic.php?t=9483 | |
The Following 2 Users Say Thank You to YellowBoss For This Useful Post: |
02-12-2024, 15:30 | #4 (permalink) |
Member: 2162000 Status: Offline Sonork: 100.1670061 Thanks Meter: 205 | status done Code: Operation: Reset Settings/Format FS [ v2.52 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X [-] Wipe [-] Userdata [+] FRP [+] Smart WARNING: Reset may delete ALL USER DATA! Reset Userdata is Off If FRP still active after reset make Userdata On and repeat operation Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port_V1633 (COM4) MODE [0]: BOOTROM; PORT: 4 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] MEID: FC9CCD741A057DB46F617ED477E97A04 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: F41DAA46F04DEEEB0AE7C7B30079991052CFD7784376D823B193902C2F154BEA SLA: Local Auth [Forced mode] Start Auth... Ok Continue Auth... Ok FF: Looking for EMI Not Found SLA: Start 0x15 Auth Passed; SEC: 0x000000E0 AGENT: MANUAL: Infinix: SEC_NEW [c7992f8b] C:\InfinityBox\CM2MT2\boot\Infinix\SEC_NEW\MTK_AllInOne_DA.bin [f814ced9] C:\Users\solusiponselpc\Downloads\perloader Infinix_Smart_7_(X6515)\perloader Infinix_Smart_7_(X6515)\preloader_x6515_h6127.bin Looking for suitable BootChain in DA... Found: MT6761; DA: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok Sync... Ok DA: Agent Started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: F401224152563131581330760FEF7AB3 crc Ok Ven: Biwin OEM: 290 ID: 415256313158 [ARV11X] PRV: 0x13 SNN: 813043695 [0x30760FEF] MM/YY: 7/2023 EMI: Init via preloader_x6515_h6127.bin EMI: MT6761 preloader_x6515_h6127.bin with 6 memory type(s) 1. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 512.00 Mb 2. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb 3. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 4.00 Gb 4. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb 5. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb 6. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb Push EMI... EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC Ok Load HW info... RAM: SRAM: 0x00080000 [ 512.00 Kb ] RAM: DRAM: 0xC0000000 [ 3.00 Gb ] EMMC CID: F401224152563131581330760FEF7AB3 crc Ok Ven: Biwin OEM: 290 ID: 415256313158 [ARV11X] PRV: 0x13 SNN: 813043695 [0x30760FEF] MM/YY: 7/2023 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0xE90000000 [ 58.25 Gb ] CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] RNID: DBCA469E03CC7E99A1F2ACB811B8B094 MEID: FC9CCD741A057DB46F617ED477E97A04 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Ok PMT: PGPT [0x64] Records: 50 Get slot info... a Select info source... boot_a [2000000] Ok Product Brand: Infinix Product Device: Infinix-X6515 Product Model: Infinix X6515 Product Name: X6515-OP SW: Infinix/X6515-OP/Infinix-X6515:12/SP1A.210812.016/240127V856:user/release-keys Patch Level: SP1A.210812.016 Display ID: X6515-H6127HIJAiAjAk-S-OP-240127V856 SW Version: 240127V856 Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2024-01-01 Build Time: 26-01-2024 18:52:11 Product Info: x6515_h6127 SW: vnd_x6515_h6127-user 12 SP1A.210812.016 532407 release-keys Product Manfct: INFINIX Product Board: Infinix-X6515 Board Platform: mt6761 Strategy: [none|generic] SmartInfo: Android Ver: 12 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] Verify config values... Ok Loaders Ok Backup exist: C:\InfinityBox\CM2MT2\backup\MT6761__FC9CCD741A057DB46F617ED477E97A04 Stage: Android OS Off Stage: FRP... [1] PROTECTION... Done Stage: Smart... Nothing to-do Reset port... Trying to reboot... Done: 00:00:58 |
