08-28-2016, 09:29 | #1 (permalink) |
No Life Poster Join Date: Sep 2011 Location: Faislabad Age: 34
Member: 1657674 Status: Offline Thanks Meter: 855 | Infintey Box Cm2 New Ver 1.55 Info Mediatek FP Platform: MT6276 initial support Identify Format FS ( reset settings ) Read Factory FW ( compatible with FlashTool ) - WorldFirst ! Scatter, EMI Configurations and HW info Read UserCode Read Full Dump Repair Security Support OLD_CA and NEW_CB revision of MT6276 MT6255 initial support Identify Format FS ( reset settings ) Read Factory FW ( compatible with FlashTool ) - WorldFirst ! Scatter, EMI Configurations and HW info Read UserCode Read Full Dump Repair Security Other FP series (MT625A, MT6260, MT6261) support revised ( Core, Flash Engine, DataDirect modules ) Repair security revised (Direct Mode and Normal mode) FW Read Engine updated, new FW types supported Mediatek SP Platform: MT8127 support revised Fixed NAND devices support Fixed some eMMC boot problems MT8163 support revised Improved NAND support Improved operations speed ( FW reading, Identify ) MT6750 support activated ( under test ) Factory FW read / Flashing FRP Reset Format FS / Reset Settings Repair Security NVRAM operations Forensic operations Extra operations: Memory testing, Init preloader etc. MTK Secure Boot phones support improved: - Format FS operation adapted for Secure devices - FixDL adapted for Secure devices - Repair Security revised for secure devices UserData operations improved - DataDirect Engine updated ( Photo/Video extraction ) FW Read Engine Revised - New types supported - Brand-Specific improvements - Files verification improved |
The Following User Says Thank You to alijaanfsd For This Useful Post: |
08-28-2016, 10:06 | #3 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,925 | Information and download links - http://forum.gsmhosting.com/vbb/f296...-more-2127702/ |
08-30-2016, 15:11 | #5 (permalink) |
Freak Poster Join Date: Oct 2013 Location: tehran Age: 37
Member: 2048880 Status: Offline Thanks Meter: 63 | ERORR AFTER FORMAT Card found : S/N : C4716F5F , v0132 Chinese Miracle II [MTK module] v 1.55 Operation : Format FileSystem [ v1.55 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8C00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 7001004D4D43303847580115DFC3514F Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , G80CM [eMMC] : FLASH_CID : 7001004D4D43303847580115DFC3514F [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000001CD000000 [eMMC] : FLASH_UCP : 7376 MiB [eMMC 8 GiB] DEV RID : 0xBC275B4D134E28E08D60B1F976B3EFDC INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Format/Reset Error! Operation Failed Elapsed: 00:02:20 Reconnect Power/Cable! |
