Old 07-11-2008, 04:27   #1 (permalink)
Member: 162328
Sonork: 100.1618216
Thanks Meter: 21
infinty Damege EEprom plz help
i tried to change imei doul sim mobile ZT 6668 smile with method 3
but its damage my mobile eeprom. i download files from infinity support
and flsh with two files flash file and eeprom file after flash still dead.
here is first log which mobile dead. i also flash backup rpl and eeprom with its
read only small size 6 kb.
COM3 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: read/check detailed information
Boot...
19200 fixed
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
chip: 0031:6386:1681
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:29EA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
slowest
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 is Ok
security area#1 backup saved: H:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.3B89E71D.[E553_X9PAPAARTF_E553_GPRS_MT6226_S01.01_1.BIN_1355 4C00].rpl
New firmware detected:
- make "Read full flash" operation
- send "backup_system_log_..." file to support: [email protected]
- send flash backup file(s) to support: [email protected]
- include in your e-mail full text from phone back label (phone name etc.)
identification#1 detection finished
device-id: 3B89E71D
identification#1 protocol ver: 04
ver. sw1: E553_X9PAPAARTF_E553_GPRS_MT6226_S01.01_1.BIN
ver. sw2: E553_X9PAPAARTF.01.1, FFB3AAEC
ffs offset/size: 00800000/001FF000
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00800000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
Detected eeprom/ffs address is non-standard: 00E00000
Posible reasons:
1. eeprom is Ok but address is non-standard
2. eeprom damaged and can't be detected
3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make flash backup for emergency case
3. repeat required operation
Are you sure that detected eeprom address is correct ?
Do you want to use standard eeprom address: 00800000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
operation terminated by user
error: critical error#1 during ffs size detection
error: can't detect eeprom/ffs address/size
error: chip layout not detected
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
file saved: H:\Program Files\InfinityBox\ChineseMiracle\system_log_3B89E7 1D_E553_X9PAPAARTF_E553_GPRS_MT6226_S01.01_1.BIN_1 3554C00_20080705-181653.B0X.bin
Finished, time used: 161 sec
Remove/Install battery now !
WARNING ! Settings will be cleared, user data erased, Imei set to default value !
Make flash backup before this procedure !
Do you want to continue ?
Action: reset
Boot...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed disabled
Boot Done
Initialize...
Initialize Done
Set baud...
slowest
Set baud Done
device-id: 3B89E71D
Posible reasons:
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
Write Done
Finalization...
formatting...
Finalization Done
file saved: H:\Program Files\InfinityBox\ChineseMiracle\system_log_3B89E7 1D_E553_X9PAPAARTF_E553_GPRS_MT6226_S01.01_1.BIN_1 3554C00_20080705-182016.B0X.bin
Finished, time used: 177 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Action: imei
imei write method: mode-2
new imei: 350697305764986
Model: Autodetect 6205-6227 NOR
19200 autodetect
CPU: MT6226
Connecting, wait...
error: can't finalize test mode
repeat operation and HOLD phone "Power" button long time !
error: operation failed !
Finished, time used: 96 sec
Imei 35069730576498 already was repaired: 7/5/2008-6:23:15 PM
Continue with this imei ?
Action: imei
imei write method: mode-3
Boot...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed disabled
Boot Done
Initialize...
flash: EC257E25082501:FFFFFF00000000
Initialize Done
Set baud...
slowest
Set baud Done
Warning: probably flash chip empty, erased, incorrectly flashed or damaged.
What to do:
1. go to software "Settings" page
2. set "Advanced chip detection method" box UN-CHECKED !
3. make flash write operation
If still no luck: send mail to support ([email protected]) with detailed description of problem,
attach the next files in your e-mail:
1. H:\Program Files\InfinityBox\ChineseMiracle\operation.log
2. H:\Program Files\InfinityBox\ChineseMiracle\cfi_***x_***x.bin
it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
standard eeprom/ffs offset assigned: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
reading [eeprom]...
file saved: H:\Program Files\InfinityBox\ChineseMiracle\eeprom_20080705-18doublepppp25.B0E.bin
imei is not detected !
What to do:
1. Power-On phone
2. wait 20-30 sec
3. Power-Off by "Power" button, don't remove battery !
4. Repeat "imei repair" procedure again
If imei can't be detected:
1. make "complete" ffs format
2. Power-On phone
3. wait 20-30 sec
4. Power-Off by "Power" button, don't remove battery !
5. Repeat "imei repair" procedure again
If imei can't be detected: read flash and send to support: [email protected]
Patch required data Fail
Finished, time used: 1324 sec
Old 07-11-2008, 16:22   #2 (permalink)
Member: 148515
Thanks Meter: 10,150
hello!
what was original phone version? E553_X9PAPAARTF_E553_GPRS_MT6226_S01.01_1 ?
what flash files did you use?
Old 07-12-2008, 08:07   #3 (permalink)
Member: 162328
Sonork: 100.1618216
Thanks Meter: 21
i flash with two files here is log
phone still dead plz help
ZTC-ZT6668E553_X9PAPAARTF_E553_GPRS_MT6226_S01.01_1__1 6m_Ru_Fr_En_Th_Vn_Cn_Hi_Cn_Ar.B0M.bin
ZTC-ZT6668-Smile_E553_X9PAPAARTF_E553_GPRS_MT6226_S01.01_1_16 m_Ru_Fr_En_Th_Ar_w_eeprom.B0M(3).bin
advanced flash detection disabled
Action: write NOR flash
"smart write" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
write: Eeprom/ffs
enhanced security fix enabled
Boot...
baud autodetection active
19200 autodetect
Connecting, wait...
CPU: MT6226
high speed disabled
Boot Done
Initialize...
flash: EC257E25082501:76737200000000
flash: Samsung D 16Mb
Initialize Done
Set baud...
460800
Set baud Done
it's time to stop: 76657273696F6E3A30320000000000000000000000000000
.damaged firmware
.damaged hardware
Can't detect eeprom/ffs area
Do you want to use standard ffs address: 00E00000 ?
standard ffs address selected by user
ffs chip: 00
reading [eeprom]...
file saved: H:\Program Files\InfinityBox\ChineseMiracle\eeprom_20080712-124628.B0E.bin
Write...
.damaged firmware
.damaged hardware
security area#1 calculation...
done
Area: Firmware
Write: Firmware
Area: Eeprom/ffs
Write: Eeprom/ffs
Write Done
Finalization...
Finalization Done
Finished, time used: 1402 sec
Old 07-12-2008, 08:11   #4 (permalink)
Member: 162328
Sonork: 100.1618216
Thanks Meter: 21
chines miracle detect first that is
device-id: 3B89E71D
Old 07-12-2008, 08:15   #5 (permalink)
Member: 162328
Sonork: 100.1618216
Thanks Meter: 21
orignal is
i flash it
ZTC-ZT6668E553_X9PAPAARTF_E553_GPRS_MT6226_S01.01_1__1 6m_Ru_Fr_En_Th_Vn_Cn_Hi_Cn_Ar.B0M.bin loaded
ver. sw2: E553_X9PAPAARTF.01.1, 9D6E0918
small differnt in ver sw2
if some one have same ver plz give me
Old 07-13-2008, 21:15   #6 (permalink)
Member: 148515
hello!
sad that you did not follow program advice and not backuped original firmware.
some chinese firmwares are different even if name is same.
this is your case.
Now in order to reapir your phone you must find exactly same model on your local market and read out backup
6120c mic point dameg plz help ..:::Gsm india:::.. Nokia Hardware & Hardware Repair 5 10-16-2012 05:02
1202 auto on battery in automatic on water dameg set plz helpe me faheemkhan Nokia Hardware & Hardware Repair 2 07-30-2010 09:30
lg kg270 sim point dameg plz help me ..:::Gsm india:::.. LG 1 09-29-2008 08:20
n3310water dameged plz help mahmoud Nokia Hardware & Hardware Repair 5 11-03-2002 00:14
how to unlock Alcatel HE1 v300 via Eeprom ??? plz HELP Svetli Alcatel & TCL Old Models 10 06-05-2000 18:34
Powered by Searchlight © 2017 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
Page generated in 0.36870 seconds with 8 queries
