12-31-2008, 09:34 | #1 (permalink) |
Junior Member Join Date: Dec 2007
Member: 648281 Status: Offline Thanks Meter: 10 | Lg mg280c successfully unlock... module v1.36 Device: LG-MG280 Checking data, wait... advanced flash detection enabled Action: unlock unlock method: standard Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E223C2200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb id: 00005258 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 011194000150290 current otp imei: 011194000150290 file saved: C:\Program Files\InfinityBox\LgA\eeprom_011194000150290_LG-MG280_20081231-121506.B1E.bin ....... Check flash Done Check space ... current eeprom imei: 011194000150290 ............................... finalization done Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... write: lock area-1 ............................... write: area-01 ...... Write Done Finished, time used: 181 sec Remove/Install battery now ! |
The Following User Says Thank You to marichu_patz For This Useful Post: |
12-31-2008, 16:23 | #3 (permalink) | |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. | |
04-11-2009, 06:47 | #4 (permalink) |
No Life Poster Join Date: Jun 2008 Location: Wish i was on Mars Age: 40
Member: 789089 Status: Offline Sonork: 100.1617*** Thanks Meter: 267 | COM5 [VCP0] selected module v1.36 Device: LG-MG280 Checking data, wait... advanced flash detection enabled Action: unlock unlock method: standard Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E223C2200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb id: 00005258 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 011194000170306 current otp imei: 011194000170306 file saved: C:\Program Files\InfinityBox\LGA\eeprom_011194000170306_LG-MG280_20090411-111517.B1E.bin ....... Check flash Done Check space ... current eeprom imei: 011194000170306 ............................... finalization done Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... write: lock area-1 ............................... write: area-01 ...... Write Done Finished, time used: 110 sec Remove/Install battery now ! |
The Following User Says Thank You to Frenzy_2020 For This Useful Post: |
LG CU500v successfully unlock | fasel | FuriousGold | 2 | 05-30-2008 07:26 |
LG KG275 Successfully Unlock in Inifity | ASHRIFF | Infinity-Box | 10 | 05-05-2008 17:43 |
LG KG110 successfully unlock by hwk | alamgir80 | HWK | 10 | 04-12-2008 11:29 |
2 Pieces of LG KE970 successfully unlocked ! | Spax | FuriousGold | 4 | 04-09-2008 17:07 |
LG KG280 Successfully Unlocked by Furious Gold | zLer | FuriousGold | 7 | 01-31-2008 07:45 |
