infity team plz send me flash file httel k3 mtk 6253 thanks advanceeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee |
hello! which is required software version? |
At first you should tell us, Which version you want..? |
Hello here is format error logs please infinity help for this problem COM3 [VCP0] selected module v3.26 Device: Autodetect 6253 NOR Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[0093]: 0089:890300000000 [INTEL] PF38F30xxM0x1xx chip size: 16Mb otp status/size: S_DA_NOR_OTP_LOCKED/00000108 NAND flash chip: not installed internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... detect sec ro... detect custom parameters... detect project-id... detect NOR info... number of areas/bytes to read: 1:00040000 reading (HW_STORAGE_NOR)... warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done Format... error: can not format: 0BFA:S_DA_HANDSET_FAT_INFO_NOT_FOUND warning: can not format: HW_STORAGE_NAND is not present Format... error: can not format: 0BFA:S_DA_HANDSET_FAT_INFO_NOT_FOUND error: last error: 0BFA:S_DA_HANDSET_FAT_INFO_NOT_FOUND Disconnect... done Finished, time used: 1 min 24 sec Remove/Install battery now ! |
hello! clearly flashing must be performed, but software version can not be detected. same working phone's dump i belive can solve problem |
Hello flash with this file your problem will solve...... http://rapidshare.com/#!download|505tl|445437429|HUIYUE53_09A_PCB01_GPRS _MT6253_S00.6253_C85K_CY_K3_ML_A_V01.BIN_FLNPF38F3 040M0Y3DE__firmware_2003102|7250 ;););) |
Download not available The following download is not available: http://rapidshare.com/files/44543742...rmware_2003102 The file of the above link no longer exists. This could be for several reasons: * The uploader deleted the file * The file contained illegal contents and was deleted from our servers by our abuse-team. * The file is incorrect * The server is busy and can not process the request. not show the file pls help me thnks |
rameez no file here pls correct link post me |
Hello contact with me on yahoo messenger |
