Old 01-27-2011, 14:22   #1 (permalink)
Member: 532257
Sonork: 1624266
Thanks Meter: 64
infity team plz send me flash file httel k3 mtk 6253
thanks advanceeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
Old 01-27-2011, 20:13   #2 (permalink)
Member: 148515
Thanks Meter: 14,904
hello!
which is required software version?
Old 01-28-2011, 13:26   #3 (permalink)
Haider Ali's Avatar
Member: 756333
Thanks Meter: 152
At first you should tell us,
Which version you want..?
Old 01-29-2011, 10:06   #4 (permalink)
rameez_gsm's Avatar
Member: 327384
Sonork: 100.1605419
Thanks Meter: 312
Hello here is format error logs please infinity help for this problem
COM3 [VCP0] selected
module v3.26
Device: Autodetect 6253 NOR
Checking data, wait...
Action: reset settings ("format ffs") NAND
interface: BROM_DLL_v3.1016.00
Connect...
Connecting...
Booting...
Release Power button now !
bootcode current/expected: 3.2/3.2
CPU: 6253:8A02:8A00
status: FF
bbchip bl ver: FE
NOR flash id[0093]: 0089:890300000000 [INTEL] PF38F30xxM0x1xx
chip size: 16Mb
otp status/size: S_DA_NOR_OTP_LOCKED/00000108
NAND flash chip: not installed
internal RAM size: 00020000
external RAM: S_DA_RAM_ERROR
done
Set baudrate (921600)...
done
ram test...
testing...
ram test passed
===> detect existing firmware structure...
detect ffs...
detect sec ro...
detect custom parameters...
detect project-id...
detect NOR info...
number of areas/bytes to read: 1:00040000
reading (HW_STORAGE_NOR)...
warning: ffs can not be detected
TCL-ID detection...
TCL-ID detection done
startup code area #1 detection...
startup code area #1 detection done
code offset: 00000000
===> done
Format...
error: can not format: 0BFA:S_DA_HANDSET_FAT_INFO_NOT_FOUND
warning: can not format: HW_STORAGE_NAND is not present
Format...
error: last error: 0BFA:S_DA_HANDSET_FAT_INFO_NOT_FOUND
Disconnect...
done
Finished, time used: 1 min 24 sec
Remove/Install battery now !
Old 01-30-2011, 20:38   #5 (permalink)
Member: 148515
hello!
clearly flashing must be performed, but software version can not be detected.
same working phone's dump i belive can solve problem
Old 01-31-2011, 10:51   #6 (permalink)
rameez_gsm's Avatar
Member: 327384
Sonork: 100.1605419
Thanks Meter: 312
Hello flash with this file your problem will solve......
http://rapidshare.com/#!download|505tl|445437429|HUIYUE53_09A_PCB01_GPRS _MT6253_S00.6253_C85K_CY_K3_ML_A_V01.BIN_FLNPF38F3 040M0Y3DE__firmware_2003102|7250
The Following User Says Thank You to rameez_gsm For This Useful Post:
Old 02-21-2011, 23:47   #7 (permalink)
Member: 1081243
Thanks Meter: 4
Download not available
The following download is not available:
http://rapidshare.com/files/44543742...rmware_2003102
The file of the above link no longer exists. This could be for several reasons:
* The uploader deleted the file
* The file contained illegal contents and was deleted from our servers by our abuse-team.
* The file is incorrect
* The server is busy and can not process the request.
not show the file pls help me
thnks
Old 02-21-2011, 23:48   #8 (permalink)
Member: 1081243
Thanks Meter: 4
Old 02-23-2011, 09:52   #9 (permalink)
rameez_gsm's Avatar
Member: 327384
Sonork: 100.1605419
Thanks Meter: 312
Hello check it again
http://rapidshare.com/files/44941395...rmware_2003102
Old 02-24-2011, 21:26   #10 (permalink)
Member: 1081243
Thanks Meter: 4
rameez
no file here pls correct link post me
Old 02-25-2011, 09:35   #11 (permalink)
rameez_gsm's Avatar
Member: 327384
Sonork: 100.1605419
Thanks Meter: 312
Hello contact with me on yahoo messenger
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 08-16-2019 20:37
Seeking for flash nokia 5110 old version (3 version) can exchange for new Tomas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 10-14-2017 20:29
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
Page generated in 0.33759 seconds with 8 queries
