INFO : BROM Level : SLA AUTH or AUTH required! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM33) MODE : BOOTROM PORT : 33 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+ARB BROM : BOOTROM MODE : 0_base : BASE_v1712 | Manual : Enabled BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 4000 0036 [0200] F3: 4000 0036 00: 1005 0000 F3: 4000 0036 [0200] F3: 4000 0036 01: 102A 0001 BROM : SOCID : 77487735A6C323B3C3AD3BE6D60BE27CA8A7A2C8D35D60C9C7 F15C906388B978 BROM : SLA BROM : SLA Passed! BROM : SLA CHALLENGE required! AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_4-19_-signed.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00000001 : DA SEND ERROR! ERROR : BROM : DL MODE ERROR INFO : BROM Level : SLA AUTH or AUTH required! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
Hello, What phone brand/model is this? Br. Infinity Box Team. |
SW clearly wrote : BROM : SLA CHALLENGE required! That mean this CPU setup to remote challenge on vendor server. According config and DA - it is REDMI 6A. |
CM2 Having Some Additional Features Which Which Original Tool Don't Have It Useful Sometimes... SLA - Server Level Authentication Right Na? |
Serial Link Authentification, right. I will add login/pass option in next CM2MT2 release. If all go well - it will be activated also over server, free and unlimited for this device. |
I Am Having A Query About SPD Protected NV Based Phones As You Know These Device Not Allow To Flash With Research Downloader If NV Crash Even With Box I Try To Write NV It Failed...Some Idiots In My City Damage NV Using XYZ Tool Or By Erase Chip I Use Some Ways To Recover Phone But I Am Unable To Repair Security Any Solution......>? Phone Also Having Sim Lock With Custom OS N Operator... |
Redmi 9a Error : Protocol Error : Fail to init Control 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port (COM4) MODE: BOOTROM PORT: 4 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM: Init passed CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: E843B0286BFB879CE254E78D8C10D2F6 BROM: Sec Level: 0x000000E7 Mode: SBC+SLA+SDA+EXT BROM: BROM|BL : 0x05|0xFE [BOOTROM] BROM: SOCID: 0B8BEE4746B68C7E47E67D945C0F3D8FB08E2C8B9CC78965E1 A36E48BF32045C BROM: SLA: Local Auth BROM: SLA: Starting Auth Error : Protocol Error : Fail to init Control 1. Check USB drivers 2. Reinstall libusb 3. Restart software Reconnect Power/Cable now |
1. Check USB drivers 2. Reinstall libusb 3. Restart software |
