05-24-2019, 10:40 | #1 (permalink) |
No Life Poster Join Date: Nov 2012 Location: Ek India Happy Wala.. :-)
Member: 1834832 Status: Offline Thanks Meter: 1,450 | INFO : BROM Level : SLA AUTH or AUTH required! 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM33) MODE : BOOTROM PORT : 33 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+ARB BROM : BOOTROM MODE : 0_base : BASE_v1712 | Manual : Enabled BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 4000 0036 [0200] F3: 4000 0036 00: 1005 0000 F3: 4000 0036 [0200] F3: 4000 0036 01: 102A 0001 BROM : SOCID : 77487735A6C323B3C3AD3BE6D60BE27CA8A7A2C8D35D60C9C7 F15C906388B978 BROM : SLA BROM : SLA Passed! BROM : SLA CHALLENGE required! AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_4-19_-signed.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00000001 : DA SEND ERROR! ERROR : BROM : DL MODE ERROR INFO : BROM Level : SLA AUTH or AUTH required! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
05-24-2019, 13:50 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | SW clearly wrote : BROM : SLA CHALLENGE required! That mean this CPU setup to remote challenge on vendor server. According config and DA - it is REDMI 6A. |
The Following 5 Users Say Thank You to JayDi For This Useful Post: |
05-24-2019, 14:32 | #4 (permalink) | |
Member: 1834832 Status: Offline Thanks Meter: 1,450 | Quote:
CM2 Having Some Additional Features Which Which Original Tool Don't Have It Useful Sometimes... SLA - Server Level Authentication Right Na? | |
05-24-2019, 20:23 | #5 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Serial Link Authentification, right. I will add login/pass option in next CM2MT2 release. If all go well - it will be activated also over server, free and unlimited for this device. |
The Following 11 Users Say Thank You to JayDi For This Useful Post: |
05-24-2019, 21:02 | #6 (permalink) | |
I Am Having A Query About SPD Protected NV Based Phones As You Know These Device Not Allow To Flash With Research Downloader If NV Crash Even With Box I Try To Write NV It Failed...Some Idiots In My City Damage NV Using XYZ Tool Or By Erase Chip I Use Some Ways To Recover Phone But I Am Unable To Repair Security Any Solution......>? Phone Also Having Sim Lock With Custom OS N Operator... | |
11-27-2022, 09:38 | #8 (permalink) |
Junior Member Join Date: Oct 2015 Location: ZIMBABWE
Member: 2480564 Status: Offline Thanks Meter: 0 | Redmi 9a Error : Protocol Error : Fail to init Control 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port (COM4) MODE: BOOTROM PORT: 4 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM: Init passed CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: E843B0286BFB879CE254E78D8C10D2F6 BROM: Sec Level: 0x000000E7 Mode: SBC+SLA+SDA+EXT BROM: BROM|BL : 0x05|0xFE [BOOTROM] BROM: SOCID: 0B8BEE4746B68C7E47E67D945C0F3D8FB08E2C8B9CC78965E1 A36E48BF32045C BROM: SLA: Local Auth BROM: SLA: Starting Auth Error : Protocol Error : Fail to init Control 1. Check USB drivers 2. Reinstall libusb 3. Restart software Reconnect Power/Cable now |
11-28-2022, 00:15 | #9 (permalink) | |
1. Check USB drivers 2. Reinstall libusb 3. Restart software | |
