04-18-2018, 15:05 | #1 (permalink) |
Freak Poster Join Date: Jul 2015 Location: Earth Age: 24
Member: 2425283 Status: Offline Thanks Meter: 95 | Info : Device is not supported yet! i think v 2.0 not officially and this version look like a joke g730-u10 Info : Device is not supported yet! cro-u00 Info : Device is not supported yet! y511 Info : Device is not supported yet! when use Manuel boot: damaged or bad any one have a successfully with this version? |
04-18-2018, 17:56 | #3 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
I think users nowdays act like a bored childs, which just ask something, without understanding what they want. You all cry about new CPU's, but when got them all and completely free - all of you started connect ancient devices and cry again, and no one care to read what have team wrote in release info. So sad. | |
04-18-2018, 18:08 | #4 (permalink) | |
No Life Poster Join Date: Apr 2014 Location: tripoli,libya Age: 36
Member: 2175357 Status: Offline Sonork: QQ:2157039171 Thanks Meter: 453 | Quote:
and where is the complete version > i am one of those members who believe in infinity team and i know you are the best here no doubt. so when team release the full version of mtk2 | |
The Following User Says Thank You to helpo For This Useful Post: |
04-18-2018, 18:26 | #5 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | What you mean on "full"? There impossible made "FULL" at once. Progress moving. I not see reason spend time right now to ancient stuff, if it already work. I not see reason spend time right now because someone want all here and now. Try make correct questions and you get answers on them. |
04-18-2018, 19:41 | #6 (permalink) |
Member: 2175357 Status: Offline Sonork: QQ:2157039171 Thanks Meter: 453 | ok since update release i to test it i have huawei y 3 2017 cro-u00 not work PTFN : MediaTek PreLoader USB VCOM (Android) (COM111) MODE : PRELOADER PORT PORT : 111 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK Info : Device is not supported yet! also lenovo c2 k10a40 PTFN : MediaTek PreLoader USB VCOM (Android) (COM67) MODE : PRELOADER PORT PORT : 67 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK Info : Device is not supported yet! and for v 1.58 with custom da files i dont used i just wait for the v2 so how can i boot the secure boot for old mtk like you said ancient mtk |
07-23-2018, 14:28 | #8 (permalink) |
Junior Member Join Date: Dec 2017 Location: Kampala
Member: 2793249 Status: Offline Thanks Meter: 7 | Important: - Software installed to new folder /CM2MT2/ and designed to support new models - Smart-Card firmware v0136 is Ok to use this version - DO NOT uninstall previous version 1.58 ! If you are trying to connect phone with new software and see a message like LEGACY MTK you should use version 1.58 for this device ! - Main Connection level revised BROM level support optimized MT6771 CPU supported! MT6771 moved from TEST to GENERAL support. Firmwware read Firmware write NVRAM read NVRAM write Reset Settings / Format FS Reset FRP Reset Privacy MemoryTool - Service Repair Security revised. Fixed issues with some NV types. - Core EMIDB updated Hint/Error explain module updated MT6758 support under test MT6765 support under test - FW reader MT6771 supported New types of firmwares supported Scatter creation optimized - SP Unlock Revised unlock support for some models Info: MT6739/MT6763/MT6771 IS NOT supported YET! - New models included Limited Oppo support (F7/A3) Limited Vivo support And diffirent other models Some other basic "generic" secure devices support optimized Known issues/warnings/info: 1. [NAND on MT6570] v1712, v1736 loader packages SHOULD NOT BE USED due to these packages have ftl/ecc errors! In result you will give read/write FW errors and rest problems at all. Recommend use v1724 for FACTORY FW flashing, v18xx line for Infinity FW Flash Read and Write 2. [NAND on MT6570] In some cases "stuck on logo" devices can be fixed only via FFU (whole flash) format! 3. [MEMORY TOOL] Partitions state on MEMORY TOOL will be empty in MT6570 NAND phones, it is normal behaviour and can not be fixed. Read-Write data, which you want, ignore "EMPTY" states. 4. ADL checksum MAY NOT WORK CORRECT on MT6570 NAND devices! Result - stuck after system/userdata partition flashing 5. FileSystem flashing on some SBC-enabled devices (except SYSTEM/CACHE/USER) may fail ! Solution - exclude them from flashing list. 6. Cheap MT6739 devices require BATTERY REMOVING after EVERY operation in most cases ! 7. Meizu support is limited by Preloader Level ( No BROM SLA ) - you must UNTICK "PMT Update" and "PRELOADER" partition from flashing list! 8. [NAND on MT6570] In some cases device MAY BE DEAD after flashing! Make sure you have TESTED firmware version! If you have download FW from internet/other source - make sure it preloader CONTAIN 3 EMI record! Preloader jc45btlc with 2 records KILL SOME DEVICE TO UNRECOVERABLE STATE ! Preloader info shown now during FW load. |
