06-02-2017, 12:45 | #1 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | InFocus M2 MSM8226 READ FIRMWARE NOT COMPLETED I have changed 5 cables still same Code: Operation : Identify [ v1.12 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 400 [MSM8x26/28] ID_BLOCK_S : 0568B000 ID_BLOCK_I : 008050E1 ID_BLOCK_L : 857F15E14CDAC7C2BD926263ACF77F4F ID_BLOCK_L : 2352FC4F40D37B880DE8AD1A688791BA Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x26 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000/00000000 Boot Ok! Brand : InFocus ProdName : M2_00WW ProdModel : InFocus M2 Device : LSO AndroidVer: 4.4.2 Manufact. : FIH SysPatch : KVT49L QLMxCPU : MSM8226 Done! Elapsed: 00:00:08 Reconnect Power/Cable! Code: Operation : Read Flash [ v1.12 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 400 [MSM8x26/28] ID_BLOCK_S : 0568B000 ID_BLOCK_I : 008050E1 ID_BLOCK_L : 857F15E14CDAC7C2BD926263ACF77F4F ID_BLOCK_L : 2352FC4F40D37B880DE8AD1A688791BA Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x26 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000/00000000 Boot Ok! Brand : InFocus ProdName : M2_00WW ProdModel : InFocus M2 Device : LSO AndroidVer: 4.4.2 Manufact. : FIH QLMxCPU : MSM8226 DevInfo : MSM8226__FIH__InFocus__ANDR_v4.4.2__InFocus_M2__LSO__M2_00WW Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : sbl1.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : ddr.bin [Read Ok] : deploy.mbn [Read Ok] : systeminfo.bin [Read Ok] : splash.img [Read Ok] : persist.img [Read Ok] : cust_nv.bin [Read Ok] : box.bin [Read Ok] : multi_splash.bin [Read Ok] : ftm.bin [Read Ok] : ftm_system.bin [Read Ok] : recovery.img [Read Ok] : boot.img [Read Ok] : NON-HLOS.bin [Read Ok] : system.img [Read Ok] : misc.img [Read Ok] : hidden.bin [Read Ok] : cda.bin [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : rf_nv.bin [Read Ok] : deviceinfo.bin [Read Ok] : securefs.bin [Read Ok] : ovks.bin [Read Ok] : gpt_pad.bin Error : Failed to read data! Unexpected end of data! Check cable, connection and drivers! Reconnect Power/Cable! Code: Operation : Read Memory [ v1.12 ] Reading selected partitions [21] [0] Read partition : MODEMST1 Saved to : C:\InfinityBox\CM2QLM\phdata\MODEMST1.bin [1] Read partition : FSC Saved to : C:\InfinityBox\CM2QLM\phdata\FSC.bin [2] Read partition : CUST_NV Saved to : C:\InfinityBox\CM2QLM\phdata\CUST_NV.bin [3] Read partition : FTMLOG Saved to : C:\InfinityBox\CM2QLM\phdata\FTMLOG.bin [4] Read partition : BOX Saved to : C:\InfinityBox\CM2QLM\phdata\BOX.bin [5] Read partition : MULTI_SPLASH Saved to : C:\InfinityBox\CM2QLM\phdata\MULTI_SPLASH.bin [6] Read partition : FTM Saved to : C:\InfinityBox\CM2QLM\phdata\FTM.bin [7] Read partition : FTM_SYSTEM Saved to : C:\InfinityBox\CM2QLM\phdata\FTM_SYSTEM.bin [8] Read partition : RECOVERY Saved to : C:\InfinityBox\CM2QLM\phdata\RECOVERY.bin [9] Read partition : BOOT Saved to : C:\InfinityBox\CM2QLM\phdata\BOOT.bin [10] Read partition : MODEM Saved to : C:\InfinityBox\CM2QLM\phdata\MODEM.bin [11] Read partition : SYSTEM Saved to : C:\InfinityBox\CM2QLM\phdata\SYSTEM.bin [12] Read partition : MISC Saved to : C:\InfinityBox\CM2QLM\phdata\MISC.bin [13] Read partition : CACHE Saved to : C:\InfinityBox\CM2QLM\phdata\CACHE.bin [14] Read partition : USERDATA Saved to : C:\InfinityBox\CM2QLM\phdata\USERDATA.bin [15] Read partition : RF_NV Saved to : C:\InfinityBox\CM2QLM\phdata\RF_NV.bin [16] Read partition : DEVICEINFO Saved to : C:\InfinityBox\CM2QLM\phdata\DEVICEINFO.bin [17] Read partition : SECUREFS Saved to : C:\InfinityBox\CM2QLM\phdata\SECUREFS.bin [18] Read partition : OVKS Saved to : C:\InfinityBox\CM2QLM\phdata\OVKS.bin [19] Read partition : GPT_PAD Error : Failed to read data! Unexpected end of data! Check cable, connection and drivers! Reconnect Power/Cable! |
06-04-2017, 09:32 | #2 (permalink) | |
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | SAME PHONE READ FIRMWARE WITH QLM v1.13 online photo storage BACKUP SECURITY Quote:
The Following User Says Thank You to Kirumira For This Useful Post: |
10-27-2017, 17:22 | #3 (permalink) | |
No Life Poster Join Date: May 2014 Location: Tamil_Nadu Rasipuram
Member: 2185083 Status: Offline Sonork: 100.1670782:dineshras Thanks Meter: 185 | Quote:
bro how to put Qualcom Mode (bootkey or EDL cable ??) | |
10-27-2017, 17:58 | #4 (permalink) |
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | I just used adb to edl.you can use edl cable also hope will works. |
