03-10-2018, 14:53 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Allah is Greatest
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | Cat B15 Tool Dl Image Fail CM2 Chinese Miracle II [MTK module] v 1.58 Operation : Fix DL Errors [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 75 ] Sync... Inital Boot Ok! BB_CPU_PID : 6575 BB_CPU_NME : [MediaTek] MT6575|MT6577_S00 BB_CPU_EXT : 0xCB00 , 0x8B00 , 0xE201 Processing BROM stage i2c Init : 0300771F SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x84 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , M00SJ [eMMC] : FLASH_CID : 150100534A5330304D0060ED6C3C3165 [eMMC] : FLASH_BRT : 0x00100000 , 0x00100000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xBF15704B06F38AE45AD804AA68818884 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! DA DLFix Passed! Done! Elapsed: 00:00:08 Reconnect Power/Cable! |
03-12-2018, 07:45 | #3 (permalink) |
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | Thanks sir But i flashed it already with 2 different firmwares. Also i tried with sptool by check DL CheckSum. But still same. Here is the firmwares i used to flash it. Proshivka_cat_b15.rar CAT_B15_EMEA_DS.1.041.0.zip CAT_B15_EMEA_DS.1.065.0.zip |
