09-17-2020, 15:40 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: on forum
Member: 566122 Status: Offline Thanks Meter: 322 | Badly need da file infinix x-557 Waiting for kind replies ,, |
09-17-2020, 15:50 | #2 (permalink) |
No Life Poster Join Date: Feb 2018 Location: Nigeria
Member: 2812901 Status: Offline Thanks Meter: 493 | Infinix hot 4 x557 already supported by cm2 since 2017 It's an 7.0 Anyway Post cm2 log results here |
The Following User Says Thank You to Oyetunde Semiu For This Useful Post: |
09-17-2020, 15:51 | #3 (permalink) | |
Have you tried easy way ? https://forum.gsmhosting.com/vbb/f29...l#post14022733 | |
09-17-2020, 15:53 | #4 (permalink) |
Member: 566122 Status: Offline Thanks Meter: 322 | I just took info for to check BOOT DONE or not ,,for infinix X-557 ,,,and my phon eis dead ,,, ithatswhy i need DA file to select it manualy and do rest process ,,,anybody can help me in this regard to provide me DA file ? here is log -: Operation : Identify [ v2.14 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM Port (COM13) MODE : PRELOADER PORT PORT : 13 Waiting BOOT ack ... PRELOADER : ACK confirm FAIL! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT MODE : INFINIX : SECURE_BASE | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SWSEC.bin AGENT : Selected AGENT doesn't have required configuration! >>> Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! |
09-17-2020, 16:17 | #8 (permalink) |
Freak Poster Join Date: May 2020 Location: Globe
Member: 2955840 Status: Offline Thanks Meter: 83 | From Experienced, infinix x557 doesn't require any special da file to do readinfo,flash.You can use any mtk tools to flash it. Make use of cm2mtk. Except they use another label for the phone.which might convince you. |
09-18-2020, 06:02 | #9 (permalink) | |
Member: 566122 Status: Offline Thanks Meter: 322 | Quote:
