09-13-2015, 10:32 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: ---> Hope
Member: 355782 Status: Offline Thanks Meter: 1,265 | iNote (itel it1403) SC7715 problem No matter EMMC or NAND Read info in service mode: Code: Operation : Check/Read Info [ v1.04 ] 1. Remove battery. Insert battery back 2. Insert cable 3. In case of SVC init problems - connect with hold "VolDown" button! ==== Wait for phone... Phone found! [ 19 ] Port Opened Sync... InitSvc Done Wait for phone... Sync... Phone Initial Info : Platform : MOCORTM_14A_W14.39_Debug Project : sc7715_modem HWInfo : sc7715_sc7715_modem Compile : 09-23-2014 14:36:40 Phone Security Info : IMEI [1] : 35594406240XXXX IMEI [2] : 35594406240XXXX BT_ADDR : 000000000000 Done Reconnect Power/Cable! Code: Operation : Check/Read Info [ v1.04 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 82 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 ion Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Code: Operation : Read NV [ v1.04 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 82 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 839 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Code: Operation : Check/Read Info [ v1.04 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 82 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 eriaSync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Generic Loader NAND v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Unknown structure detected! Check correct model selection! Elapsed: 00:00:23 Reconnect Power/Cable! Code: Operation : Read NV [ v1.04 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 82 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 M0Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Generic Loader NAND v1.0 MĪSending FLASH FDL FLASH FDL Ready! Boot Ok! Unknown structure detected! Something went wrong :( If phone work normally - check correct selection (Model,FlashType)! Elapsed: 00:00:19 Reconnect Power/Cable! |
The Following User Says Thank You to Nasir Mobiles For This Useful Post: |
09-13-2015, 14:57 | #4 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Means you need to select atleat sldr file or pac file of this model to perform your required operation. As in few cases it needs to select sldr or original pac file to read pattern or format spd sp. Br. | |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
09-13-2015, 15:06 | #5 (permalink) |
Member: 355782 Status: Offline Thanks Meter: 1,265 | ok got it. where to find sldr or pac for sc7715 ? or is it possible to read (sldr or pac) with infinity or any other tool. I have a phone and want to save for future operations. Thanks |
09-13-2015, 15:24 | #6 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: In My Limit
Member: 610502 Status: Offline Sonork: 100.1618428 Thanks Meter: 161 | Respected Bro.. Quote:
C:\InfinityBox\CM2SPD\Models Go there and select the file.. B/R Sheraz... | |
09-13-2015, 15:36 | #7 (permalink) | ||
For now search for original pac file. Br. Quote:
Not any sldr can work with any phone. Br. | ||
09-13-2015, 16:11 | #8 (permalink) | |
Member: 355782 Status: Offline Thanks Meter: 1,265 | Quote:
