01-22-2016, 20:00 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Algeria
Member: 56090 Status: Offline Thanks Meter: 162 | Inovalley GSm60 with virus Chinese Miracle II [MTK module] v 1.40 Operation : Remove Viruses [SmartAV] [ v1.40 ] SmartAV Conf : 100/80/2000 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 18 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D43303447580E4C3B5451C7 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , G40CM [eMMC] : FLASH_CID : 7001004D4D43303447580E4C3B5451C7 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E6800000 [eMMC] : FLASH_UCP : 3688 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait #7 : Data CRC Error : B50C , B205 #0 : Data CRC Error : 4ED8 , 0000 #0 : Data CRC Error : 4ED8 , 0000 #0 : Data CRC Error : 4F32 , 0000 #0 : Data CRC Error : 4ED8 , 0000 #0 : Data CRC Error : 4F32 , 0000 #0 : Data CRC Error : 4ED8 , 0000 Scan Done, infected files found : 24 Removing infected files and scripts ... DDCleaner : Error clear item #0 DDCleaner : Error clear item #1 DDCleaner : Error clear item #2 DDCleaner : Error clear item #3 DDCleaner : Error clear item #4 DDCleaner : Error clear item #5 DDCleaner : Too much errors! Break! Infected files not found! Breaking rest operations. Done! Done! Elapsed: 00:00:36 Reconnect Power/Cable! also format manually or with mtk dont solve the problem , system is corrupted need firmware Salam |
01-22-2016, 20:19 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. There is problem with cable/connection or battery. Start from seek NORMAL good USB cable. Then REMOVE all HUB's and etc, just cable in PC. |
01-22-2016, 22:32 | #5 (permalink) | ||
Member: 56090 Status: Offline Thanks Meter: 162 | Driver problem ,version 2.0.1136.0 work fine and tampon reception emission value decrease to 4(emisision -7(recption) Quote:
01-22-2016, 22:32 | #6 (permalink) | ||
01-25-2016, 15:48 | #9 (permalink) |
Member: 56090 Status: Offline Thanks Meter: 162 | solution is flashing the device with same firmware f not found search firmware same cpu id and flash only userdata and cache image for sure virus will be removed that what i do and now phone work well Salam |
