02-26-2017, 15:33 | #1 (permalink) |
Freak Poster Join Date: May 2010 Location: Egypt Age: 33
Member: 1298419 Status: Offline Sonork: 100.1672105 Thanks Meter: 69 | Install Apk is Blocked I have this payment machine that is based on MT6572 CPU. The Firmware installed in that machine is customized not to install any apk. If i try to install any APK , it will give this Message Developer option in android Setting can not be enabled. There is no option to enable Unkown Sources in android Setting. So , is there any way to install APK on this machine ? Ps , i had read the firmware from that machine as a scatter file. |
The Following User Says Thank You to expenaticx For This Useful Post: |
02-26-2017, 18:41 | #4 (permalink) |
No Life Poster Join Date: May 2016 Location: Madina, Accra, GHANA
Member: 2575234 Status: Offline Thanks Meter: 1,134 | And if you tap on the build number 7 times, you don't see Developer options enabled? If tapping on build number 7 times don't enable developer options, you can try others like kernel version or stuff like that |
02-26-2017, 19:14 | #6 (permalink) |
Member: 2575234 Status: Offline Thanks Meter: 1,134 | Use Maui META 3G ver 6.1316.1 to boot phone into meta mode and use adb command or Android Multi Tools to check if adb is offline or online after meta mode. If adb is online, you can use command to try and install apk and see result. But you still need to explore the phone very well to locate where the developer enabler option is hidden. Sometimes it is in strange location Last edited by Kwesi_Roy_GH; 02-26-2017 at 19:20. |
02-27-2017, 10:06 | #7 (permalink) |
Member: 1298419 Status: Offline Sonork: 100.1672105 Thanks Meter: 69 | I successfully gain access to ADB via this factory recovery mode. ADB commands is working. Put system and data partition is read only and can not be mounted to copy apk inside /system/app (permission is not permitted). Via this recovery mode i can also boot into fastboot mode. Is there any way to add apk inside system.bin that i already red from the phone , and then flash system.bin to the phone again ! |
02-27-2017, 10:31 | #9 (permalink) |
Member: 2575234 Status: Offline Thanks Meter: 1,134 | If you get adb command working, then you can install apk file without problem Get this 1. Put on desktop and extract it 2. Put the apk file in the folder 3. Press 'Shift' and right click after opening the folder 4. run adb command to install apk. eg. you want to install whatsapp.apk put the whatsapp.apk file in the folder and run this command 'adb install whatsapp.apk' If you want to reinstall or update the app run this command 'adb install -r whatsapp.apk' |
02-27-2017, 10:41 | #10 (permalink) |
Member: 1298419 Status: Offline Sonork: 100.1672105 Thanks Meter: 69 | There in no root or custom recovery available for this brand. MobiPrint 3 |
02-27-2017, 10:48 | #11 (permalink) |
Member: 1298419 Status: Offline Sonork: 100.1672105 Thanks Meter: 69 | I gain access to ADB commands via this Recovery Mode When i try to install APK it show that When i enter normal mode , APK is not installed. |
02-27-2017, 10:57 | #12 (permalink) |
Member: 2575234 Status: Offline Thanks Meter: 1,134 | You must wait and see the word 'succes' on the interface before disconnecting phone Did you put the apk files in the folder before running the command? You can as well connect phone to mobogenie in the factory mode to install the app |
02-27-2017, 11:46 | #14 (permalink) |
Member: 2575234 Status: Offline Thanks Meter: 1,134 | Well bro, if not success, then I guess you need to work on this first but I wonder if you can gain root access with your system 'read only' For root, you can download desktop version of kingroot or kingo root or others and give a try Last edited by Kwesi_Roy_GH; 02-27-2017 at 11:54. |
02-27-2017, 12:40 | #15 (permalink) |
Freak Poster Join Date: Feb 2014
Member: 2136362 Status: Offline Thanks Meter: 31 | Dear all masters, Open adb kit (Command Prompt). type adb shell type su You should see a # in your prompt. type mount -o rw,remount -t yaffs2 /dev/block/mtdblock3 /system. check whether it works or not. p.s: i am a novice and this commands was searched from xda indeed. |
The Following User Says Thank You to pintu mangaraj For This Useful Post: |
