Old 02-10-2007, 19:27   #1 (permalink)
Member: 449821
installation problem... please help
hi,
I am having problem installing the infinity box.
I have these three devices in my device manager
1. e-gate Virtual Reader Enumerators -> e-gate Virtual Reader Enumerator
2. Smart card readers -> e-gate USB Smart card reader
3. e-gate USB Smart Cards -> e-gate USB Smart Card
But I do not have the (as in this pictures)
Infinity USB Serial Port
http://forum.gsmhosting.com/vbb/atta...5&d=1113325293
thank you
Old 02-10-2007, 19:40   #2 (permalink)
zinoubinabil's Avatar
Member: 84268
Sonork: 100.114149
Thanks Meter: 2,568
hi
what u mean exactly??
plz more detail to can help you.....
i think now you can useyour infinity box without problem
Old 02-11-2007, 03:55   #3 (permalink)
Member: 449821
as stated in the pictures which I got off from the FAQ link, you need to the the Infinity Box USB Serial(Com5) under comp part of the device manager.
But I do not have it.
Is it OK to use to use my Infinity Box now?
Old 02-11-2007, 04:12   #4 (permalink)
Member: 449821
I am having trouble with this step, I do not see Infinity USB Serial Port (COMX)”
4.3. Select Com Port (WinXP example)
Make right mouse click on “My Computer” icon and select “Properties”.
Go to page “Hardware” and press “Device Manager” button.
Go to “Ports (COM & LPT)” section and find “Infinity USB Serial Port (COMX)”, where X is your Box COM-Port number. Use this COM-Port No for future operation.
Old 02-11-2007, 09:09   #5 (permalink)
Member: 84268
Sonork: 100.114149
Thanks Meter: 2,568
hi;
please check this links
Infinity virgin needs help
Box not found
Old 02-11-2007, 14:23   #6 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,296
It can be that port name is not exactly "Infinity USB Serial Port". Probably it has another name like "usb serial port".
Old 02-11-2007, 17:15   #7 (permalink)
Member: 449821
thanks for your reply.
Under COM & LPT, I ONLY see three devices : COM1, COM2, AND LPT1
Under Universal Bus Controllers Tab, I do see two devices appear after pluggin in the infinity box
1. Generic USB Hub
2. FTDI FT8U2XX Device
HOWEVER, I do not see what port is the infinity box assigned to after going into the two device above.
thanks for your help. I really need to unlock my phone because right now I have no phone to use.
Old 02-11-2007, 18:00   #8 (permalink)
Member: 130995
You need to update driver for "FTDI FT8U2XX Device".
Select drivers for this device from folder:
x:\Program Files\InfinityBox\Drivers\Cable
Old 02-11-2007, 20:47   #9 (permalink)
Member: 449821
I have update driver for "FTDI FT8U2XX Device".
please advise what to do next.
thanks
Old 02-11-2007, 21:17   #10 (permalink)
Member: 130995
Next you will see new "usb to com" in "COM ports"
Old 02-11-2007, 21:24   #11 (permalink)
Member: 449821
I do not see usb to come under COM ports. I only see COM1, COM2, LPT1
I connect the infinity box using the supplied usb cable to my computer. It is switched to "ON", and the other switched to F-BUS. I connect the PAN X60 to the RJ45 near TX/RX lights. The box says "card version" on the back. It says "Infinity High-Speed Tool Box on the front.
thanks again for your help. I am really desperate to get this to work.
Old 02-11-2007, 23:26   #12 (permalink)
Member: 130995
Hi,
the problem is: your Box now detected by your PC as "FTDI FT8U2XX Device" (due to previus installed drivers).
It's need to change/update FTDI drivers for this device to "VCP" drivers so you will see ordinary COM port in your system after this.
Correct drivers located in x:\Program Files\InfinityBox\Drivers\Cable folder in your PC (after Infinity-Box drivers installation).
Please, try to change drivers for "FTDI FT8U2XX Device" device to drivers supplied with Infinity-Box.
Old 02-12-2007, 05:36   #13 (permalink)
Member: 449821
thank you for your help. the usb to serial finally shows up after I reinstall everything and using the supplied driver as opposed to downloading from the website.
USTPro2 installation problem ?? pLease help rmcellular UST Pro II 0 09-08-2008 22:15
""hwk Install Problem - Please Help Me Urgent"" rajeevpchandran HWK 11 06-17-2008 10:56
""se Tool2 Installation Problems - Please Help Me""" rajeevpchandran SETool2 2 06-11-2008 10:39
hwk installation Problem Please help gsmhosting HWK 1 05-11-2008 16:25
Page generated in 0.37554 seconds with 8 queries
