08-01-2015, 17:11 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Intex 3g+ V12 Emmc Format Done :) Test Report 1.03 Code: Chinese Miracle II [SPD module] v 1.03 SLDR Load Ok BB CPU : SC7715 Aqua3G+ [eMMC 4GiB] [RAM 512MiB] For disable SLDR - select PAC or other SLDR or re-select CPU in settings tab! Operation : Check/Read Info [ v1.03 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : w131_kew_111 Model Brand : Intex Model Device: w131_kew_111 AndrVersion : 4.4.2 BaseBand CPU: W131_KEW_111 CompileDate : 1428494978 Project Ver : MocorDroid test-keys Model Ext : Aqua_3G+ Elapsed: 00:00:32 Reconnect Power/Cable! Format FFS Code: Operation : Format File System [ v1.03 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 13 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x00000000257FB000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Done! Elapsed: 00:00:31 Reconnect Power/Cable! Need More? Stay Tuned With Us |
The Following 6 Users Say Thank You to pradeep_kus For This Useful Post: |
