Old 02-07-2016, 15:21   #1 (permalink)
rehmani's Avatar
Member: 333199
Sonork: may i help u just pm me
Thanks Meter: 2,405
intex aqua 3 life read ff cant supported
company -intex
model-intex aqua 3 life
problem-hang on logo
first try with different sldr in boot mode cant success
seond in svc mode reset done and set working
Operation : Check/Read Info [ v1.14 ]
1. Remove battery. Insert battery back
2. Insert cable
3. In case of SVC init problems - connect with hold "VolDown" button!
 ====  Wait for phone...
Phone found! [ 77 ]
Port Opened
Sync...
InitSvc Done
Wait for phone...
Sync...
Phone Initial Info :
Platform : MOCORTM_14B_W15.24_Debug
Project  : sc7731g_CP0_modem
HWInfo   : sc7731g_CP0_modem
Compile  : 07-28-2015 11:08:42
Phone Security Info :
IMEI [1] : 911464401------
IMEI [2] : 911464401------
BT_ADDR  : 000000000000
SelfInfo :
BatVoltage : 3.706 V
Done
Reconnect Power/Cable!
Operation : Format File System / Reset Settings [ v1.14 ]
Settings : SmartFormat is On
2. Insert cable
Phone found! [ 77 ]
Port Opened
Sync...
InitSvc Done
Wait for phone...
Sync...
Init Ok , reset settings ...
Format Ok!
Done
Elapsed: 00:00:34
SLDR Load Ok
BB CPU  : SC7731
HTC 326G UMS SEC
For disable SLDR - select PAC or other SLDR or re-select CPU in settings tab!
Operation : Read FullFlash [ v1.14 ]
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
3. Insert cable
Phone found! [ 72 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : Spreadtrum Boot Block version 1.1
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Unknown structure detected! Something went wrong :(
If phone work normally - check correct selection (Model,FlashType)!
Elapsed: 00:00:12
SLDR Load Ok
BB CPU  : SC7731
Huawei Y336-U02 (Y3C)
3. Insert cable
Phone found! [ 72 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SPRD3
Sending FLASH FDL
Boot failed!
Boot failed!
SLDR Load Ok
BB CPU  : SC7731
Huawei Y541-U02 (Y5C)
3. Insert cable
Phone found! [ 72 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Elapsed: 00:00:12
SLDR Load Ok
BB CPU  : SC7731
Huawei Y560-U02 (Y5C)
3. Insert cable
Phone found! [ 72 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Elapsed: 00:00:10
SLDR Load Ok
BB CPU  : SC7731
SC7731 Alcatel
3. Insert cable
Phone found! [ 72 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
SLDR Load Ok
BB CPU  : SC7731
SC773x eMMc Loader v2.0
3. Insert cable
Phone found! [ 72 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC773x eMMC v2.0 Loader Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Elapsed: 00:00:09
The Following User Says Thank You to rehmani For This Useful Post:
Old 02-07-2016, 15:55   #2 (permalink)
mbiborna's Avatar
Member: 770503
Thanks Meter: 1,215
Hi bro. Did u try to boot with selecting Different SC7731 pac file ?
Some time it's also working
Page generated in 0.16983 seconds with 8 queries
