02-22-2016, 06:42 | #1 (permalink) |
Freak Poster Join Date: Aug 2013 Location: roorkee Age: 23
Member: 2006027 Status: Offline Sonork: 1645658 Thanks Meter: 36 | intex Aqua 3G not set hang on logo NAND not supported yet! Done! Elapsed: 00:00:11 Reconnect Power/Cable! Operation : Check / Read Info [ v1.41 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : 009800BC009000660076001600080000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1 [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/00/NIM_Px-1 DEV RID : 2546FF4F60DDADAFB262F88B96ED677E INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Info read not done Erased phone or unsupported FlashIc? You can change settings : Settings -> Other -> NAND init Mode Done! Elapsed: 00:00:18 Reconnect Power/Cable! |
