09-01-2015, 10:59 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: CLOUD Age: 40
Member: 486357 Status: Offline Sonork: 100.1602846 Thanks Meter: 1,220 | Intex Aqua 4G+ imei repair success but same 4*40 Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6735 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6735_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 520001154D313238B7B60042411967E4 DA Stat : v4.2 on BBID : 0x93 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BM128 [eMMC] : FLASH_CID : 150100523832314D4200B6B7E4675241 [eMMC] : FLASH_LEN : 0x00000003A3E00000 INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! IMEI [00] : 911445100471387 IMEI [01] : 911445100571384 Set IMEI [00] : 911445100471387 Set IMEI [01] : 911445100571384 Prepare finished. Security check required! Wait for phone... Phone found! [ 4 ] Sync... PostCheck Ok! Repair done! Done! Elapsed: 00:00:34 Reconnect Power/Cable! after repair show 4*40 |
09-01-2015, 11:39 | #2 (permalink) |
Member: 486357 Status: Offline Sonork: 100.1602846 Thanks Meter: 1,220 | Aqua T5 Imei Repair error Operation : Repair Security [ v1.27 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 002C00BC009000660054000000000000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x8B DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0088 , [Micron] NAND_MT29C4G48MAAHBAAKS_5WT [NAND] : FLASH_DIE : 002C 00BC 0090 0066 0054 0000 0000 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! NAND Flash not supported yet in that mode! Done! Elapsed: 00:00:05 Reconnect Power/Cable! |
09-01-2015, 12:18 | #4 (permalink) | |
Member: 486357 Status: Offline Sonork: 100.1602846 Thanks Meter: 1,220 | Quote:
which phone you talk about if Aqua T5 then 1 click repair volcano box 65XX new method NO need flash no need to fix NVRAM Right Now Not Success with Valcono new CPU_ID : 6735 thats y i buy CM2 CM2 also Not success show IMEI Repair Done BUT same IMEI SHOW 4*40 | |
09-01-2015, 12:36 | #5 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Then you made mistake. Back and use your volcano. | |
09-01-2015, 12:43 | #6 (permalink) | |
Brother Very easy to Understand my Post's 1st post IMEI repair success show But not Same IMEI INvaild 2nd post repair IMEI Give Error and you give me advice 4r my 2nd post | |
