12-12-2015, 13:29 | #1 (permalink) |
Freak Poster Join Date: May 2012
Member: 1763380 Status: Offline Thanks Meter: 86 | need MT6572__HUAWEI__HUAWEI_Y520-U22__HWY520-U__4.4.2__ALPS.KK1.MP6.V1 also try with this Y520-U22V100R001C328B109 still no luck, lcd going blank |
The Following User Says Thank You to den fatih For This Useful Post: |
12-12-2015, 14:25 | #2 (permalink) | |
No Life Poster Join Date: Jul 2013 Location: uganda
Member: 1976974 Status: Offline Sonork: 100.1641825 Thanks Meter: 92 | Quote:
extract it flash with Sp tool or infinity tool & post results. Where to find uploaded files: - Login to Support Server-2 - Go to /flashfiles/0-CommunityUploads/ folder | |
The Following 2 Users Say Thank You to kawalya For This Useful Post: |
12-12-2015, 14:33 | #3 (permalink) |
No Life Poster Join Date: Apr 2014 Location: Charsadda kpk Age: 41
Member: 2166444 Status: Offline Thanks Meter: 298 | Mt6572__huawei__huawei y520-u22__hwy520-u__4.4.2__alps.kk1.mp6.v1 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 18 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 45010053454D3034473C3494C8AA9101 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0045 , OEM : 0100 [eMMC] : FLASH_INF : G40ME [eMMC] : FLASH_CID : 45010053454D3034473C3494C8AA9101 [eMMC] : FLASH_LEN : 0x00000000EC000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : HUAWEI ProdName : Y520-U22 ProdModel : HUAWEI Y520-U22 Device : HWY520-U AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP6.V1 MODEM : BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V36_F2_P9_1_wg_ n EXTRA : LCD [0] : otm8018b_dsi_vdo LCD [1] : otm8018b_dsi_vdo_dijing LCD [2] : otm8018b_dsi_vdo_dijing_9806E LCD [3] : otm8018b_dsi_vdo_9806E LCD [4] : otm8018b_dsi_vdo_cs_9806E LCD [5] : otm8018b_dsi_vdo_lcm_drv_9806E_ii LCD [6] : otm9806E_dsi_vdo_txd_hsd LCD Res : 854x480 TOUCH [0] : msg2133a CAM [0] : ov5645_qt_mipi_yuv CAM [1] : ov5645_mipi_yuv CAM [2] : gc0312_yuv CAM [3] : hi708_yuv CAM [4] : hi541_mipi_yuv MODEM : ckt72_we_72_kk_hspa_18 LOCALE : en_US es_ES zh_CN zh_TW ru_RU pt_BR fr_FR de_DE tr_TR it_IT in_ID ms_MY vi_VN ar_EG th_TH pt_PT nl_NL el_GR hu_HU ro_RO cs_CZ my_MM ko_KR pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA da_DK fi_FI nb_NO sv_SE en_GB zh_HK ja_JP sr_RS ca_ES et_EE sl_SI fa_IR hi_IN |
The Following User Says Thank You to GSM KPK For This Useful Post: |
12-13-2015, 04:22 | #4 (permalink) | |
Member: 1763380 Status: Offline Thanks Meter: 86 | Quote:
hi sorry i can not find y520-u22 display error fix ok on support | |
12-13-2015, 05:57 | #5 (permalink) |
Member: 1763380 Status: Offline Thanks Meter: 86 | Operation : Check / Read Info [ v1.38 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1101003030344739305113D6D209B105 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0011 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 09G40 [eMMC] : FLASH_CID : 1101003030344739305113D6D209B105 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : HUAWEI ProdName : Y520-U22 ProdModel : HUAWEI Y520-U22 Device : HWY520-U AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP6.V1 MODEM : BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V36_F2_P9_1_wg_ n EXTRA : LCD [0] : otm8018b_dsi_vdo LCD [1] : otm8018b_dsi_vdo_dijing LCD [2] : otm8018b_dsi_vdo_dijing_9806E LCD [3] : otm8018b_dsi_vdo_9806E LCD [4] : otm8018b_dsi_vdo_cs_9806E LCD [5] : otm8018b_dsi_vdo_lcm_drv_9806E_ii LCD [6] : otm9806E_dsi_vdo_txd_hsd LCD Res : 854x480 TOUCH [0] : msg2133a CAM [0] : ov5645_qt_mipi_yuv CAM [1] : ov5645_mipi_yuv CAM [2] : gc0312_yuv CAM [3] : hi708_yuv CAM [4] : hi541_mipi_yuv MODEM : ckt72_we_72_kk_hspa_18 LOCALE : en_US es_ES zh_CN zh_TW ru_RU pt_BR fr_FR de_DE tr_TR it_IT in_ID ms_MY vi_VN ar_EG th_TH pt_PT nl_NL el_GR hu_HU ro_RO cs_CZ my_MM ko_KR pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA da_DK fi_FI nb_NO sv_SE en_GB zh_HK ja_JP sr_RS ca_ES et_EE sl_SI fa_IR hi_IN Done! Elapsed: 00:00:14 Reconnect Power/Cable! Scatter Load Ok , BaseBand : MT6572 , Project : ckt72_we_72_kk , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.38 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 21 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1101003030344739305113D6D209B105 DA Stat : v4.2 on BBID : 0x88 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00A8 DRAM Init Ok , 0x20000000 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0011 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 09G40 [eMMC] : FLASH_CID : 1101003030344739305113D6D209B105 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : ckt72_we_72_kk , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled Switching to HSUSB HSUSB Init Ok BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3701 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x0000000090040000 Flash Pre-Erase Done, time used : 00:00:07 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_ckt72_we_72_kk.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0013 Update PMT by user request Repartition Done! Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:03:12 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:20 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:03:59 Reconnect Power/Cable! thanks now working good... |
12-13-2015, 10:40 | #9 (permalink) |
No Life Poster Join Date: Aug 2011 Location: Afghanistan
Member: 1646177 Status: Offline Sonork: 100.1604654 Thanks Meter: 369 | |
12-16-2015, 10:52 | #11 (permalink) |
No Life Poster Join Date: Jan 2007
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | hi bro tested firmware CM2 Read link MT6572__HUAWEI__HUAWEI Y520-U22__HWY520-U__4.4.2__ALPS.KK1.MP6.V1 BY-Kabul 6824170 |
The Following User Says Thank You to kabul For This Useful Post: |
12-24-2015, 11:50 | #12 (permalink) | |
No Life Poster Join Date: Dec 2013
Member: 2085670 Status: Offline Thanks Meter: 35 | Quote:
03-11-2016, 15:58 | #14 (permalink) |
No Life Poster Join Date: Mar 2015 Location: kapurthala punjab
Member: 2362867 Status: Offline Sonork: ththtuu Thanks Meter: 659 | Y520-U22 Dispaly Error Fix OK - Download - 4shared - ali shams try this file its 10000000000% working without any pass |
The Following User Says Thank You to sachu2002 For This Useful Post: |
03-12-2016, 13:14 | #15 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | How to upload firmware files to support area - http://forum.gsmhosting.com/vbb/f296...oader-2001567/ How to download firmware files - Infinity-Box/Dongle - http://forum.gsmhosting.com/vbb/f296...pport-2048891/ How to download firmware files - Infinity [BEST] - http://forum.gsmhosting.com/vbb/f641...pport-2041626/ |
