intex aqua fish recovery problum intex aqua fish after formate cm2 show only recovery-connect usb cable and open telnet to address 10.42.66.66 i flash with q file tool but same i reset with putty tool but same any help |
your solution here Download http://the.earth.li/~sgtatham/putty/.../x86/putty.exe 1. Right click RNDIS update driver, let me choose driver, under network adaptors, choose microsoft corporation, select Remote NDIS compatible device, ignore warning message, select yes. 2. download http://the.earth.li/~sgtatham/putty/.../x86/putty.exe 3. open putty select telnet host name 10.42.66.66 and click open press 1. Welcome to the recovery tool! The available options are: 1) Reset device to factory state 2) Reboot device 3) Shell 4) Perform file system check 5) Run sshd 6) Exit Type the number of the desired action and press [Enter]: 1 ALL DATA WILL BE ERASED! Clears everything from the device and reverts the software back to factory state. This means LOSING EVERYTHING you have added to the device (e.g. updates, apps, accounts, contacts, photos and other media). Are you really SURE? [y/N] y u 2 logical volume(s) in volume group "sailfish" now active [OK] No lockcode has been set. Proceeding... 0 logical volume(s) in volume group "sailfish" now active 0 logical volume(s) in volume group "sailfish" now active Logical volume "root" successfully removed Logical volume "home" successfully removed Volume group "sailfish" successfully removed Labels on physical volume "/dev/mmcblk0p28" successfully wiped Physical volume "/dev/mmcblk0p28" successfully created Volume group "sailfish" successfully created Logical volume "root" created. Logical volume "home" created. resize2fs 1.42.4 (12-June-2012) Resizing the filesystem on /dev/sailfish/root to 640000 (4k) blocks. The filesystem on /dev/sailfish/root is now 640000 blocks long. resize2fs 1.42.4 (12-June-2012) Resizing the filesystem on /dev/sailfish/home to 2749440 (4k) blocks. The filesystem on /dev/sailfish/home is now 2749440 blocks long. /var/lib/platform-updates/flash-aboot.sh ... Flashing to mmcblk0p4 176+1 records in 176+1 records out 724135 bytes (724 kB) copied, 0.0213132 s, 34.0 MB/s OK /var/lib/platform-updates/flash-bootimg.sh ... Flashing to mmcblk0p20 2689+1 records in 2689+1 records out 11016192 bytes (11 MB) copied, 0.363559 s, 30.3 MB/s OK /var/lib/platform-updates/flash-modem.sh ... Flashing to mmcblk0p1 12116+1 records in 12116+1 records out 49628672 bytes (50 MB) copied, 1.35982 s, 36.5 MB/s OK /var/lib/platform-updates/flash-persist.sh ... Flashing to mmcblk0p22 Unsparsing '/boot/persist.img' to '/boot/persist.img.tmp'.. 8192+0 records in 8192+0 records out 33554432 bytes (34 MB) copied, 0.896068 s, 37.4 MB/s OK /var/lib/platform-updates/flash-recoveryimg.sh ... Flashing to mmcblk0p24 2996+1 records in 2996+1 records out 12273664 bytes (12 MB) copied, 0.38048 s, 32.3 MB/s OK /var/lib/platform-updates/flash-rpm.sh ... Flashing to mmcblk0p6 39+1 records in 39+1 records out 159956 bytes (160 kB) copied, 0.00644557 s, 24.8 MB/s OK /var/lib/platform-updates/flash-sbl1.sh ... Flashing to mmcblk0p2 60+1 records in 60+1 records out 246944 bytes (247 kB) copied, 0.00747729 s, 33.0 MB/s OK /var/lib/platform-updates/flash-sec.sh ... Flashing to mmcblk0p19 0+1 records in 0+1 records out 80 bytes (80 B) copied, 0.00171479 s, 46.7 kB/s OK /var/lib/platform-updates/flash-splash.sh ... Flashing to mmcblk0p16 675+1 records in 675+1 records out 2765312 bytes (2.8 MB) copied, 0.149655 s, 18.5 MB/s OK /var/lib/platform-updates/flash-tz.sh ... Flashing to mmcblk0p8 127+1 records in 127+1 records out 523304 bytes (523 kB) copied, 0.0194993 s, 26.8 MB/s OK [DONE] DEVICE RECOVERED! [NOTE]: please note that since the device will now reboot, after you press [Enter], this connection will be interrupted and you won't be able to interact with this screen anymore. Press [Enter] to reboot the device... Best Regards Rohitchhotu |
seam problem Recovery: connect usb cable and open telnet address 10.42.66.66 |
I hope you did fully reflash using QFIL package first. Then you did factory reset via telnet. If so .... last idea is to de-brand that device, and try update it after with Jolla C firmware. So, with putty (or any other client), make telnet session, and choose option 3 (SHELL), then carefully read THIS and do required steps After done, exit shell and select option 1 from menu. p.s.2 that procedure above will update "auto-restore/factory reset" partition to this version : JollaC-2.0.2.43-l500d-in-0.0.1.24 , so after making factory reset, that will be version of device, and at the same time it should be debranded from intex. test and post results. b.r. Alex |
