Old 05-03-2017, 15:56   #1 (permalink)
Member: 1051138
Sonork: 123456
Thanks Meter: 74
intex aqua fish recovery problum
intex aqua fish after formate cm2
show only recovery-connect usb cable and open telnet to address 10.42.66.66
i flash with q file tool but same i reset with putty tool but same any help
Old 08-15-2017, 11:38   #2 (permalink)
Member: 1768437
Thanks Meter: 19
your solution here
Download http://the.earth.li/~sgtatham/putty/.../x86/putty.exe
1. Right click RNDIS update driver, let me choose driver, under network adaptors, choose microsoft corporation, select Remote NDIS compatible device, ignore warning message, select yes.
2. download http://the.earth.li/~sgtatham/putty/.../x86/putty.exe
3. open putty select telnet host name 10.42.66.66 and click open press 1.
Welcome to the recovery tool!
The available options are:
1) Reset device to factory state
2) Reboot device
3) Shell
4) Perform file system check
5) Run sshd
6) Exit
Type the number of the desired action and press [Enter]:
1
ALL DATA WILL BE ERASED! Clears everything from the device and reverts the
software back to factory state. This means LOSING EVERYTHING you have added to
the device (e.g. updates, apps, accounts, contacts, photos and other media).
Are you really SURE? [y/N] y
u 2 logical volume(s) in volume group "sailfish" now active
[OK] No lockcode has been set. Proceeding...
0 logical volume(s) in volume group "sailfish" now active
Logical volume "root" successfully removed
Logical volume "home" successfully removed
Volume group "sailfish" successfully removed
Labels on physical volume "/dev/mmcblk0p28" successfully wiped
Physical volume "/dev/mmcblk0p28" successfully created
Volume group "sailfish" successfully created
Logical volume "root" created.
Logical volume "home" created.
resize2fs 1.42.4 (12-June-2012)
Resizing the filesystem on /dev/sailfish/root to 640000 (4k) blocks.
The filesystem on /dev/sailfish/root is now 640000 blocks long.
Resizing the filesystem on /dev/sailfish/home to 2749440 (4k) blocks.
The filesystem on /dev/sailfish/home is now 2749440 blocks long.
/var/lib/platform-updates/flash-aboot.sh ...
Flashing to mmcblk0p4
176+1 records in
176+1 records out
724135 bytes (724 kB) copied, 0.0213132 s, 34.0 MB/s
OK
/var/lib/platform-updates/flash-bootimg.sh ...
Flashing to mmcblk0p20
2689+1 records in
2689+1 records out
11016192 bytes (11 MB) copied, 0.363559 s, 30.3 MB/s
OK
/var/lib/platform-updates/flash-modem.sh ...
Flashing to mmcblk0p1
12116+1 records in
12116+1 records out
49628672 bytes (50 MB) copied, 1.35982 s, 36.5 MB/s
OK
/var/lib/platform-updates/flash-persist.sh ...
Flashing to mmcblk0p22
Unsparsing '/boot/persist.img' to '/boot/persist.img.tmp'..
8192+0 records in
8192+0 records out
33554432 bytes (34 MB) copied, 0.896068 s, 37.4 MB/s
OK
/var/lib/platform-updates/flash-recoveryimg.sh ...
Flashing to mmcblk0p24
2996+1 records in
2996+1 records out
12273664 bytes (12 MB) copied, 0.38048 s, 32.3 MB/s
OK
/var/lib/platform-updates/flash-rpm.sh ...
Flashing to mmcblk0p6
39+1 records in
39+1 records out
159956 bytes (160 kB) copied, 0.00644557 s, 24.8 MB/s
OK
/var/lib/platform-updates/flash-sbl1.sh ...
60+1 records in
60+1 records out
246944 bytes (247 kB) copied, 0.00747729 s, 33.0 MB/s
OK
/var/lib/platform-updates/flash-sec.sh ...
Flashing to mmcblk0p19
0+1 records in
0+1 records out
80 bytes (80 B) copied, 0.00171479 s, 46.7 kB/s
OK
/var/lib/platform-updates/flash-splash.sh ...
Flashing to mmcblk0p16
675+1 records in
675+1 records out
2765312 bytes (2.8 MB) copied, 0.149655 s, 18.5 MB/s
OK
/var/lib/platform-updates/flash-tz.sh ...
Flashing to mmcblk0p8
127+1 records in
127+1 records out
523304 bytes (523 kB) copied, 0.0194993 s, 26.8 MB/s
OK
[DONE] DEVICE RECOVERED!
[NOTE]: please note that since the device will now reboot, after you press
[Enter], this connection will be interrupted and you won't be able to interact
with this screen anymore.
Press [Enter] to reboot the device...
Best Regards Rohitchhotu
Old 03-23-2019, 06:45   #3 (permalink)
rimiaafif's Avatar
Member: 1326433
Sonork: yahoo
Thanks Meter: 22
2) Reboot device
3) Shell
5) Run sshd
6) Exit
1
176+1 records in
176+1 records out
OK
2689+1 records in
2689+1 records out
OK
12116+1 records in
12116+1 records out
OK
8192+0 records in
8192+0 records out
OK
2996+1 records in
2996+1 records out
OK
39+1 records in
39+1 records out
OK
60+1 records in
60+1 records out
OK
0+1 records in
0+1 records out
OK
675+1 records in
675+1 records out
OK
127+1 records in
127+1 records out
OK
all success but
seam problem
Recovery: connect usb cable and open telnet address 10.42.66.66
Old 03-24-2019, 22:56   #4 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 5,951
I hope you did fully reflash using QFIL package first.
Then you did factory reset via telnet.
If so .... last idea is to de-brand that device, and try update it after with Jolla C firmware.
So, with putty (or any other client), make telnet session,
and choose option 3 (SHELL), then carefully read THIS and do required steps
After done, exit shell and select option 1 from menu.
p.s.2 that procedure above will update "auto-restore/factory reset" partition to this version :
JollaC-2.0.2.43-l500d-in-0.0.1.24 , so after making factory reset, that will be version of device,
and at the same time it should be debranded from intex.
test and post results.
b.r.
Alex
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
The Following 2 Users Say Thank You to Brka For This Useful Post:
Page generated in 0.38886 seconds with 7 queries
