02-02-2015, 09:10 | #1 (permalink) |
Freak Poster Join Date: Jan 2015
Member: 2320752 Status: Offline Thanks Meter: 9 | intex aqua i-5 I checked hardware it is fine.Can I reive it with software? there is no flash file in download site.Can you please help me arrange it? Here is idfentify log, Operation : Check / Read Info [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 204A0190594E4958EBA11648DF40B302 DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... DA start Failed! Check battery , cable , drivers and try try again Boot Error! Operation Failed Elapsed: 00:00:02 Reconnect Power/Cable! Thanks, |
02-02-2015, 09:30 | #2 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Preloader Status : Not active (Erased) you cant do anything if loder erased! find factory firmware and try to flash by factory Tool! |
02-02-2015, 16:21 | #5 (permalink) |
Member: 2320752 Status: Offline Thanks Meter: 9 | I found file here but not flasher. How can I flash it with cm2mtk? It has scatter file & scatter file option is not highlighting. http://forum.gsmhosting.com/vbb/f945...09/index2.html |
02-02-2015, 16:27 | #6 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: India
Member: 1039903 Status: Offline Thanks Meter: 2,040 | Quote:
The Following User Says Thank You to VIJAY2U2 For This Useful Post: |
02-02-2015, 16:41 | #7 (permalink) |
Member: 2320752 Status: Offline Thanks Meter: 9 | When I load scatter file it says uboot checksum failed. Any body has working file for intex aqua i-5? I think this file has problem. It shows same error in SP_Flash_Tool_v5.1352.01 & in SP_Flash_Tool_v3.1244.0 also. |
02-02-2015, 16:44 | #8 (permalink) | |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Quote:
Use This Latest SP_Flash_Tool. http://forum.gsmhosting.com/vbb/10820432-post37.html Post Result Please. | |
02-03-2015, 07:20 | #9 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | @jataarya Intex Aqua-i5 uses flashing tool named- SPMultiPortFlashDownloadProject Here is the link for official flasher for Intex Aqua-i5- tool-12052013 Br. |
02-03-2015, 08:37 | #11 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Check and select correct comport and select sel All Auto Pl option. And this is Infinity support section so better post in intex sub forum for more support. Br. |
02-03-2015, 09:11 | #13 (permalink) | |
Check It, http://forum.gsmhosting.com/vbb/f782...issue-1828199/ | |
The Following User Says Thank You to MyGSM World For This Useful Post: |
06-17-2015, 17:02 | #15 (permalink) |
Junior Member Join Date: Jun 2009
Member: 1052584 Status: Offline Thanks Meter: 1 | it is very simple contact on [email protected] |
