05-22-2016, 13:24 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: India Age: 37
Member: 145082 Status: Offline Thanks Meter: 798 | Intex Aqua Q3 no service plz help !!!! 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 36 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! Clear DYNAMIC DATA ... Clear DYNAMIC DATA done! Elapsed: 00:00:12 Reconnect Power/Cable! Bad data , incorrect or damaged file! Bad data , incorrect or damaged file! Operation : Clear Dynamic Data [ v1.18 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 36 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! Clear DYNAMIC DATA ... Clear DYNAMIC DATA done! Elapsed: 00:00:12 Reconnect Power/Cable! Loading : Intex_Aqua_Q3_V07_Indina_SER_20150121.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC7730_UMS PacVersion : Intex_Aqua_Q3_V07_Indina_SER_20150121 FastCheck : 0x003690F092 Loading files ... File : fdl1.bin File : fdl2.bin File : nvitem.bin File : nvitem_wcn.bin File : u-boot-spl-16k.bin File : SC7702_sc7731g_band128.bin File : DSP_DM_G2.bin File : SC8800G_x30g_wcn_dts_modem.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : LOGO.bmp File : LOGO.bmp File : prodnv.img File : cache.img File : u-boot.bin File : SC7730_UMS.xml Load Ok! Operation : Flash [ v1.18 ] ======= Flash Files set for flashing : [ MCU ] : Intex_Aqua_Q3_V07_Indina_SER_20150121.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC7730_UMS PacVersion : Intex_Aqua_Q3_V07_Indina_SER_20150121 File : fdl1.bin File : fdl2.bin File : nvitem.bin File : nvitem_wcn.bin File : u-boot-spl-16k.bin File : SC7702_sc7731g_band128.bin File : DSP_DM_G2.bin File : SC8800G_x30g_wcn_dts_modem.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : LOGO.bmp File : LOGO.bmp File : prodnv.img File : cache.img File : u-boot.bin 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 36 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! [FL] : User decide to make whole erase [FL] : FLASH_FULL_FORMAT executing , wait ... [FL] : FLASH_FULL_FORMAT Ok! [FL] : Enabled NVM update. Will program all NVM images found in FW ! PMTManager : Load 0x17 records PMTManager : PMT Update Ok! Flashing now [FlashProc] : NVM Update Current ID : NV_W Current Part : wfixnv1 [FlashProc] : Ok! [FlashProc] : NVM Update Current ID : NV_WCN Current Part : wcnfixnv1 [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEUBOOT Current Part : uboot [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : SPLLOADER Current File : u-boot-spl-16k.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_W Current File : SC7702_sc7731g_band128.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : DSP_W Current File : DSP_DM_G2.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_WCN Current File : SC8800G_x30g_wcn_dts_modem.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOT Current File : boot.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : RECOVERY Current File : recovery.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : SYSTEM Current File : system.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : USERDATA Current File : userdata.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOTLOGO Current File : LOGO.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : FASTBOOT_LOGO Current File : LOGO.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH Current Part : wruntimenv1 [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH_WCN Current Part : wcnruntimenv1 [FlashProc] : Ok! [FlashProc] : CODE Current ID : PRODNV Current File : prodnv.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : CACHE Current File : cache.img Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEMISC Current Part : misc [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : UBOOTLOADER Current File : u-boot.bin Flashing now ... [FlashProc] : Ok! Elapsed: 00:02:12 Reconnect Power/Cable! Operation : Repair Security [ v1.18 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 36 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! Write new security data : IMEI1 : 911426850035200 IMEI2 : 911426850035218 Step #1 Ok Step #2 Ok Write done! Elapsed: 00:00:16 Reconnect Power/Cable! I have flashed the phone and repaired the imei but no service need nv data file waiting for the some serious reply help me supporters |
05-22-2016, 16:03 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Check Manual network search mode. Does phone seek and find some networks? Check emergency call. Is there any result? If none on both - time to check HW ( PA ) part. |
05-22-2016, 17:03 | #3 (permalink) |
Member: 145082 Status: Offline Thanks Meter: 798 | the phone was working before flashing it was just working slow and now on no service i need nv data file i got one on forum here : http://forum.gsmhosting.com/vbb/f715.../#post11653138 but it is for miracle box need one for cm2 plzzzz help the phone is @ ma store for more than a month |
05-22-2016, 18:03 | #5 (permalink) |
Member: 145082 Status: Offline Thanks Meter: 798 | could u give me the link for the factory file we can try with other file h/w ver : v2.0 s/w ver : v07 please get me the file i will flash and post results now |
05-22-2016, 19:33 | #6 (permalink) |
Member: 145082 Status: Offline Thanks Meter: 798 | could i flash s/w version v09 to this phone ??? waiting for reply main reason for asking me again and again is coz the phone was working perfect before flashing it was just slow hangs for a while and then process |
05-22-2016, 20:00 | #7 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | You can flash any fw, which you want to see inside. Another question is - will that phone run under that FW or not. Anyway - you can in any moment reflash it to need FW. |
06-03-2016, 08:05 | #9 (permalink) |
Junior Member Join Date: Feb 2016 Location: Mumbai India
Member: 2536538 Status: Offline Thanks Meter: 0 | Hello after flashing the NV file do not forget to change the imei to the correct one which your phone has. I forgot to mention this step so hopefully the network will be fixed for anyone who is facing this problem. |
06-15-2016, 19:01 | #14 (permalink) |
Member: 145082 Status: Offline Thanks Meter: 798 | Operation : Repair Security [ v1.18 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 12 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! Write new security data : IMEI1 : 911426850035200 IMEI2 : 911426850035218 Step #1 Ok Step #2 Ok Write done! Elapsed: 00:00:14 Reconnect Power/Cable! done all as said same no service |
