03-16-2016, 14:41 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: india
Member: 942210 Status: Offline Sonork: 1511 Thanks Meter: 91 | PreLoader : NOT Active [ Erased ] 6572 nand Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : 009800BC009000660076001600080000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x10000000 NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1 [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/00/NIM_Px-1 DEV RID : A201493A6AB713FE1DE19647A1A35208 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! i flash the og firmware with og tool flashing done but set is not power on plz help me argent phone problem press the data button then set hang |
03-16-2016, 15:01 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Find exact firmware version written on phone back sticker and flash phone with spft. Br. Infinity Box Support Team. |
03-16-2016, 15:08 | #3 (permalink) |
Member: 942210 Status: Offline Sonork: 1511 Thanks Meter: 91 | i flash the set same firmware ver on written phone back sticker phone sw ver v13K http://firmwarefile.com/intex-aqua-3g |
03-16-2016, 18:40 | #4 (permalink) | |
No Life Poster Join Date: May 2013 Location: Far From Home..:(
Member: 1948608 Status: Offline Thanks Meter: 1,743 | Quote:
03-17-2016, 04:56 | #5 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | Quote:
look here and follow process ur set alive http://forum.gsmhosting.com/vbb/f781...-tool-1992409/ | |
The Following User Says Thank You to sneha For This Useful Post: |
03-17-2016, 06:44 | #6 (permalink) |
Member: 942210 Status: Offline Sonork: 1511 Thanks Meter: 91 | Thanks sneha follow with your process my set is alive but cm2 imei not write Operation : Repair Security [ v1.43 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : 009800BC009000660076001600080000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x10000000 NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1 [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/00/NIM_Px-1 DEV RID : A201493A6AB713FE1DE19647A1A35208 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! NAND Flash not supported yet in that mode! |
03-17-2016, 07:09 | #7 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Use AT:Temporary mode. Br. Infinity Box Support Team. | |
