Old 10-06-2015, 04:22   #1 (permalink)
vasimsiyana's Avatar
Member: 1272558
Sonork: 100.1669383
Thanks Meter: 317
Intex aqua r3 flashing error
Card found: S/N : 819F5988 , v0129
Chinese Miracle II [RDA module] v 1.03
Load file...
RDATotal : Intex_Aqua_R3_V17_Indian_SER_20150720_0948_rda_tot al.bin
Load Ok
Operation : Flash
======= Settings
Settings : Factory Settings Enabled
======= Flash
Files set for flashing :
RDATotal File : Intex_Aqua_R3_V17_Indian_SER_20150720_0948_rda_tot al.bin
Load Ok : PDL1
Load Ok : PDL2
Load Ok : bootloader
Load Ok : boot
Load Ok : system
Load Ok : modem
Load Ok : customer
Load Ok : recovery
Waiting phone ...
Connect battery, press and hold 'VolUP' + 'PowerOn' buttons
Connect USB cable and keep hold buttons, until phone will be detected
Device found!
Handshake Ok!
[PDL] : Setting FlashMode ...
[PDLBoot] : Sending First PDL ...
[PDLBoot] : First Boot Ok!
[PDLBoot] : Sending Second PDL ...
[PDLBoot] : Second Boot Ok!
Boot Finished!
Handshake with FL Ok!
Factory Defaults Enabled, will reset UserData and Settings!
Format UDA partition ...
Format USER Ok
[PDLFlash] : Sending All Images
[PDLFlash] : Processing now BOOTLOADER
Flashing ...
[PDLFlash] : Flash region done!
Flashing ...
[PDLFlash] : ERROR! PartitionFinalize rejected! Check FlashFile and connection!
Flashing Done!
Reboot Phone
Elapsed: 00:00:31
Reconnect Power/Cable!
Old 10-06-2015, 08:01   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 16,059
Hello. Charge battery fully, then flash again.
The Following User Says Thank You to JayDi For This Useful Post:
Old 10-06-2015, 12:03   #3 (permalink)
Member: 1272558
Sonork: 100.1669383
Thanks Meter: 317
ok im try thanks.........
Old 10-07-2015, 04:54   #4 (permalink)
Member: 1272558
Sonork: 100.1669383
Thanks Meter: 317
my problum has solved. as you said thanx again
The Following User Says Thank You to vasimsiyana For This Useful Post:
Page generated in 0.20470 seconds with 7 queries
