06-18-2015, 14:20 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | .:::<<<< Intex Aqua R3 Rda 8810 Format FFS Done All Inside >>>>:::.. ;) Code: Chinese Miracle II [RDA module] v 1.02 Operation : Format File System Settings : SmartFormat is On Waiting phone ... Connect battery, press and hold 'VolUP' + 'PowerOn' buttons Connect USB cable and keep hold buttons, until phone will be detected Device found! Handshake Ok! Processing UBOT init ... UBOOT FCS Init Ok! Processing FL init ... Handshake with FL Ok! Factory Defaults : Will reset UserData and Settings! Format USERDATA partition ... Format USER Ok Reboot Phone Elapsed: 00:00:22 Reconnect Power/Cable! Code: Operation : Read FullFlash ======= Settings Settings : Make Calibration file Waiting phone ... Connect battery, press and hold 'VolUP' + 'PowerOn' buttons Connect USB cable and keep hold buttons, until phone will be detected Device found! Handshake Ok! Processing UBOT init ... UBOOT FCS Init Ok! Processing FL init ... Handshake with FL Ok! Calibration read done Verify and build IFC Calibration Data Saved to : RDA8810_Calibration.ifc Reboot Phone Elapsed: 00:00:13 Reconnect Power/Cable! Code: Operation : Factory Area Rebuild [Repair IMEI] Waiting phone ... Connect battery, press and hold 'VolUP' + 'PowerOn' buttons Connect USB cable and keep hold buttons, until phone will be detected Device found! Handshake Ok! Processing UBOT init ... UBOOT FCS Init Ok! Processing FL init ... Handshake with FL Ok! Checking Security Info ... Detected 2 Sim Slot(s) Current Phone IMEI's : IMEI1 : 000000000000000 IMEI2 : 000000000000000 Connectivity Data : BT_MAC : 000000000000 WiFi_MAC : DE7843E5AC25 New Phone IMEI's : IMEI1 : 91141555383478-7 IMEI2 : 91141555383479-5 Accepting changes ... Security Block accepted! Security Repair Done! Reboot Phone Elapsed: 00:00:07 Reconnect Power/Cable! Need More?? , Just Stay Tuned-With Us |
The Following 3 Users Say Thank You to pradeep_kus For This Useful Post: |
06-18-2015, 18:02 | #4 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Even wrong flashing can be recovered. But need flash mobile twice after such. | |
The Following 4 Users Say Thank You to JayDi For This Useful Post: |
09-30-2015, 08:55 | #5 (permalink) |
Junior Member Join Date: Aug 2013
Member: 2013774 Status: Offline Sonork: [email protected] Thanks Meter: 4 | Repair Security Code: Operation : Factory Area Rebuild [Repair IMEI] Waiting phone ... Connect battery, press and hold 'VolUP' + 'PowerOn' buttons Connect USB cable and keep hold buttons, until phone will be detected Device found! Handshake Ok! Processing UBOT init ... UBOOT FCS Init Ok! Processing FL init ... Handshake with FL Ok! Checking Security Info ... Detected 2 Sim Slot(s) Current Phone IMEI's : IMEI1 : 000000000000000 IMEI2 : 000000000000000 Connectivity Data : BT_MAC : 000000000000 WiFi_MAC : DE7843E5AC25 New Phone IMEI's : IMEI1 : 91141555383478-7 IMEI2 : 91141555383479-5 Accepting changes ... Security Block accepted! Security Repair Done! Reboot Phone Elapsed: 00:00:07 Reconnect Power/Cable! No Any Kinds Of, Dead Risk Need More?? , Just Stay Tuned-With Us THANKS BRO........ VERRY NICE TRIK |
The Following User Says Thank You to HUANSARI For This Useful Post: |
10-01-2015, 17:25 | #6 (permalink) |
Freak Poster Join Date: Nov 2010 Location: CHOLOMAN
Member: 1440339 Status: Offline Sonork: 100.1616914;CHOLOMAN Thanks Meter: 116 | Handset problem after intex logo display white Operation : Format File System Settings : SmartFormat is On Waiting phone ... Connect battery, press and hold 'VolUP' + 'PowerOn' buttons Connect USB cable and keep hold buttons, until phone will be detected Device found! Handshake Ok! Processing UBOT init ... UBOOT FCS Init Ok! Processing FL init ... Handshake with FL Ok! Factory Defaults : Will reset UserData and Settings! Format USERDATA partition ... Format USER Ok Reboot Phone Elapsed: 00:00:18 Reconnect Power/Cable! Problem not solve. Operation : Flash ======= Settings Settings : Factory Settings Enabled ======= Flash Files set for flashing : RDATotal File : Intex_Aqua_R3_V12_rda_total.bin Load Ok : PDL1 Load Ok : PDL2 Load Ok : bootloader Load Ok : boot Load Ok : system Load Ok : modem Load Ok : customer Load Ok : recovery Waiting phone ... Connect battery, press and hold 'VolUP' + 'PowerOn' buttons Connect USB cable and keep hold buttons, until phone will be detected Device found! Handshake Ok! [PDL] : Setting FlashMode ... [PDLBoot] : Sending First PDL ... [PDLBoot] : First Boot Ok! [PDLBoot] : Sending Second PDL ... [PDLBoot] : Second Boot Ok! Boot Finished! Handshake with FL Ok! Factory Defaults Enabled, will reset UserData and Settings! Format UDA partition ... Format USER Ok [PDLFlash] : Sending All Images [PDLFlash] : Processing now BOOTLOADER File : Intex_Aqua_R3_V12_rda_total.bin Flashing ... [PDLFlash] : Flash region done! [PDLFlash] : Processing now BOOT File : Intex_Aqua_R3_V12_rda_total.bin Flashing ... [PDLFlash] : ERROR! PartitionFinalize rejected! Check FlashFile and connection! Flashing Done! Reboot Phone Elapsed: 00:00:19 Reconnect Power/Cable! Handset not powering up. Any procedure to alive again? |
10-02-2015, 12:00 | #7 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Use last CM2RDA module, charge battery fully, then try again. IF error will be same at same file - then resolder it for start. |
