Old 05-27-2015, 12:02   #1 (permalink)
tejas243404's Avatar
Member: 725038
Sonork: 100.1675584
Thanks Meter: 288
intex aqua style 4.0 pin lock not done
hello infinity team pin lock not done
intex most modal not support to infinity box
intex aqua style 4.0 cpu tmk 6582
Operation : Reset Privacy Lock [ v1.21 ]
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BB_CPU_NM : [MediaTek] MT6582_S00
Processing BROM stage
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 45010053454D3034472853D94D5D7191
DA Stat : v4.2 on BBID : 0x87
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0045 , OEM : 0100
[eMMC] : FLASH_INF : G40ME
[eMMC] : FLASH_CID : 45010053454D3034472853D94D5D7191
[eMMC] : FLASH_LEN : 0x00000000EC000000
INT RAM : 0x00020000
EXT RAM : 0x20000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Checking data ...
Privacy Lock not set!
Done!
Elapsed: 00:00:13
Reconnect Power/Cable!
Old 05-27-2015, 12:08   #2 (permalink)
sunilkumar70791's Avatar
Member: 1432329
Sonork: 100.1615863
Thanks Meter: 1,626
Hi,
i think this is pin lock not privacy lock, try to format your mobile , i hope your problem solve
Old 05-27-2015, 12:15   #3 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Too sad, when people no feel difference between "Privacy Protection Password" and " Pin Password " , which phone clearly write on lock screen.
"And not support" and e.t.c. - facts , please. Otherwise - leave that section.
Old 02-29-2016, 08:29   #4 (permalink)
Member: 816244
Sonork: 100.1626537
Thanks Meter: 91
format with sptool than flash your phone and than write imei your problem 100000000000% solve
Old 02-29-2016, 09:13   #5 (permalink)
JayDi's Avatar
Member: 462970
Wake up, my dear necroposter. Next time try use your little brain first.
The Following User Says Thank You to JayDi For This Useful Post:
Old 03-02-2016, 22:05   #6 (permalink)
Member: 816244
Sonork: 100.1626537
Thanks Meter: 91
Post here if u have solution.
Sent from my 2014818 using Tapatalk
Page generated in 0.17187 seconds with 8 queries
