03-27-2016, 12:03 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | intex aqua v3g read firmware error company-intex model -aqua v3g problem-locked read info Code: Operation : Check/Read Info [ v1.16 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 61 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Loader NAND v1.1 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : NAND Flash , Structure : Ok! Reading extended info ... Model Name : Aqua V3G Model Brand : Intex Model Device: Intex AndrVersion : 4.4.2 BaseBand CPU: SCX15_SP7715GA CompileDate : 1/5/2015 3:44:32 AM Project Ver : INTEX_AQUA V3G_V02_INDIA Model Ext : Aqua V3G ExtraInfo : HWInfo not exists, normal phone ExtraInfo : GSM Phone Elapsed: 00:00:25 Reconnect Power/Cable! Code: Operation : Format File System / Reset Settings [ v1.16 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 61 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Loader NAND v1.1 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected NAND Flash , Structure detect Ok! Formatting NAND Flash Format UserData Format Ok! Format Cache Format Ok! Done! Elapsed: 00:00:16 Reconnect Power/Cable! Code: Operation : Read FullFlash [ v1.16 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 61 ] Open Port Failed! Reconnect Power/Cable! Operation : Read FullFlash [ v1.16 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 61 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Loader NAND v1.1 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Detected NAND Flash , Structure detect Ok! [FW_READER] : Step #1 Passed! [FW_READER] : Step #2 Passed! [FW_READER] : Initialize Ok , 0x13 , NAND : b256k [FW_READER] : Step #3 Passed! Model Name : Aqua V3G Model Brand : Intex Model Device: Intex AndrVersion : 4.4.2 BaseBand CPU: SCX15_SP7715GA Project Ver : INTEX_AQUA V3G_V02_INDIA Model Ext : Aqua V3G [Read Mode] : HSUSB : 0x3000 [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : prodnv_b256k.img [Read Ok] : nvitem_w.bin [Read Ok] : nvitem_wcn.bin [Read Ok] : sc7715_modem.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : CP2._CP2_WCN_14C_W14.45_Release.bin [Read Ok] : logo_320x480.bin [Read Ok] : boot.img ReadErr : MajorErr , 0x3000:0x0000:0x0D3E9000 ReadErr : MajorErr , 0x2000:0x0000:0x0D3E9000 ReadErr : MajorErr , 0x1000:0x0000:0x0D3E9000 ReadErr : FatalErr , 0x1000:0x0000:0x0D3E9000 [Read Failed] : DataRead failed : Connection fault! [READ_ERROR] : Connection/Battery or some unknown problem! Reconnect Power/Cable! |
03-27-2016, 12:58 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Take another one cable. Some original one. Also can try to clean usb jack as well. |
