08-06-2014, 13:00 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: India
Member: 1039903 Status: Offline Thanks Meter: 2,040 | Intex_Crystal_3.5 Format Fail Format Fail Code: Operation : Format FileSystem [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 8 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : AAAAEDCB96E58C4D75D6C33CBCF9A67F BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C800 6000 1800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F4 , [GigaDevice] GD25LQ128 [0] : FLASH_DIE : 00C8 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 SDS : 0x00FF0000 , 0x00010000 Backup done Executing FFS FORMAT now... FAT_RANGE : 0x00E90000-0x00FEFFFF , LEN : 0x00160000 DA_RET : DA_IN_PROGRESS 0000000B DA_RET : FORMAT_FAILED Done! Elapsed: 00:00:14 Reconnect Power/Cable! Read Flash OK Code: Operation : Read Flash [ v0.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 8 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : AAAAEDCB96E58C4D75D6C33CBCF9A67F BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C800 6000 1800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F4 , [GigaDevice] GD25LQ128 [0] : FLASH_DIE : 00C8 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 SDS : 0x00FF0000 , 0x00010000 Read Flash now Read Ok , 16777216 bytes read Check and collect compile info File_Info : PCB01_MT6260_S00.Intex_Crystal_3.5_R14_India_201406060935.201406060935.bin FileVersion : Intex_Crystal_3.5_R14_India_201406060935 Saved to : F:\InfinityBox\CM2MTK\Read_out\PCB01_MT6260_S00.Intex_Crystal_3.5_R14_India_201406060935.201406060935.bin Done! Elapsed: 00:01:02 Reconnect Power/Cable! FILE LINK:-PCB01_MT6260_S00.Intex_Crystal_3.5_R14_India_20140 6060935.201406060935 - Download - 4shared |
The Following User Says Thank You to VIJAY2U2 For This Useful Post: |
