-   Infinity-Box (http://forum.gsmhosting.com/vbb/f296/)
-   -   invalid imei mt 6575/6577 (http://forum.gsmhosting.com/vbb/f296/invalid-imei-mt-6575-6577-a-2075015/)
abderrahmane bi 04-06-2016 23:53
how to solve this problem invalid imei
Operation : Fix Unknown BaseBand [ v1.44 ]
User accepted FixBB operation!
Wait for phone...
Phone found! [ 126 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6575
BB_CPU_NME : [MediaTek] MT6575|MT6577_S00
BB_CPU_EXT : 0xCB00 , 0x8B00 , 0xE201
Processing BROM stage
i2c Init : 0300771F
SpeedSet : 0000
VChrgSet : 0x28 , BatStat : 0x02
WD Disable stat : 0x0000
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01
Sending and initialize DA ...
Running DA ver.3.2 on BBID : 0x84
Initialize Memory ...
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , M00SJ
[eMMC] : FLASH_CID : 150100534A5330304D00D3D315AA4FD1
[eMMC] : FLASH_BRT : 0x00100000 , 0x00100000 , 0x00020000
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : FDEC6373C8F25B7B0C70602121AEF663
INT RAM : 0x00020000
EXT RAM : 0x20000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Step #1
Step #1 ... Ok
Step #2
Step #2 ... Ok
Reset Done!
Done!
Elapsed: 00:00:18
Reconnect Power/Cable!
Finish at : [06/04/2016 / 23:34:48]
Start at : [06/04/2016 / 23:40:59]
Operation : Repair Security [ v1.44 ]
Wait for phone...
Sync...
Init Ok, waiting for phone ...
Reading initial info, wait...
Phone Info :
Security Info :
IMEI [1] : Damaged!
IMEI [2] : Damaged or not exists
Read Ok!
Update IMEI[1] to : 357428021205671 failed , record not exist or NVRAM damaged!
Update IMEI[2] to : 357428021205689 failed , record not exist or NVRAM damaged!
Done!
Elapsed: 00:05:20
Finish at : [06/04/2016 / 23:46:19]
thank you
JayDi 04-07-2016 07:05
1. Check BaseBand state. If it Ok go to p2.
2. Use CM2 : Permanent repair method.
abderrahmane bi 04-08-2016 23:28
hello
after that i have no service
thank you
PASSIONATE_BOYS 04-09-2016 07:29
Hello,
Check if imei is not blacklisted and is valid.
You can also try to write good NVRAM.
Br.
Infinity Box Support Team.
Page generated in 0.12356 seconds with 5 queries
