10-26-2020, 09:47 | #1 (permalink) |
Freak Poster Join Date: Feb 2018 Location: Congo Brazzaville
Member: 2809120 Status: Offline Thanks Meter: 83 | Invens A10 Firmware needed please i need Invens A 10 Firmware ; when reading i got below information Device info : Patch Level : MRA58K Display ID : Series_A_A10_Android_8.1_V01_2020-05-22 Ver. Incmt : root-103233 Ver. CodeName : REL Ver. Release : 8.1 Sec. Patch : 2019-12-01 Build Time : 22.05.2020 Product Brand : Series A Product Name : A10 Product Device : A10 Product Board : sp7731gea_hdr Product Manfct : Series A Board Platform : sc8830 Product Info : A10 Product Model : A10 Platform Version: MOCORTM_14B_MP_7731G_W17.22.4_Debug Project Version: sc7731g_CP0_modem BASE Version: TM_BASE_W17.22.4 MMI Version: sc7731g_modem HW Version: sc7731g_CP0_modem CMP_Time : 05-31-2017 21:23:59 MODEM TAG : MOCORTM_14B_MP_7731G_W17.22.4_Debug_TM_BASE_W17.22 .4_sc7731g_CP0_modem_sc7731g_CP0_modem_sc7731g_mod em thanks for sharing regards leroi |
10-26-2020, 12:10 | #2 (permalink) |
Member: 2809120 Status: Offline Thanks Meter: 83 | Dear already copy in other phone will share it on support Card found : 21B1154E , v0145 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.07 Load IDBase v8331 Ok! Operation : Read FW [ v2.07 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731x_BASE : SC7731GEA_eMMC_1GB_NS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Device info : Patch Level : MRA58K Display ID : Series_A_A10_Android_8.1_V01_2020-05-22 Ver. Incmt : root-103233 Ver. CodeName : REL Ver. Release : 8.1 Sec. Patch : 2019-12-01 Build Time : 22.05.2020 Product Brand : Series A Product Name : A10 Product Device : A10 Product Board : sp7731gea_hdr Product Manfct : Series A Board Platform : sc8830 Product Info : A10 Product Model : A10 AndroidVer : 8 VlnrLevel : 0x01 SC8830__Series_A__A10__8.1__Series_A_A10_Android_8 .1_V01_2020-05-22__MRA58K__A10 Read : prodnv.img ExtSparse : Compression ratio : 12% Read : phase.cfg Read : wmodem.bin Read : wdsp.bin Read : wnvitem.bin Read : modem_wcn.img Read : wcnnvitem.bin Read : boot_logo.bmp Read : fastboot_logo.bmp Read : logo2.bin Read : logo3.bin Read : logo4.bin Read : logo5.bin Read : boot.img Read : system.img ExtSparse : Compression ratio : 87% Make : persist.img Read : sysinfo.bin ExtSparse : Compression ratio : 4% Make : cache.img Read : recovery.img Make : userdata.img Read : u-boot.bin Read : u-boot-spl.bin Firmware size : 0x4C0BEB80 ( 1,19 GiB ) Android Info saved : _Android_info.txt Reconnect Power/Cable! Done! Elapsed: 00:10:32 |
The Following 2 Users Say Thank You to leroi2018 For This Useful Post: |
10-29-2020, 12:21 | #4 (permalink) |
Member: 2809120 Status: Offline Thanks Meter: 83 | |
11-17-2020, 14:51 | #7 (permalink) |
Member: 2809120 Status: Offline Thanks Meter: 83 | INVENS A9 READ by CM and will share on support Card found : 21B1154E , v0146 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.09 Load IDBase v8331 Ok! Operation : Identify [ v2.09 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731x_BASE : SC7731GEA_eMMC_1GB_NS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Device info : Platform Version: MOCORTM_14B_MP_7731G_W17.22.4_Debug Project Version: sc7731g_CP0_modem BASE Version: TM_BASE_W17.22.4 MMI Version: sc7731g_modem HW Version: sc7731g_CP0_modem CMP_Time : 05-31-2017 21:23:59 MODEM TAG : MOCORTM_14B_MP_7731G_W17.22.4_Debug_TM_BASE_W17.22 .4_sc7731g_CP0_modem_sc7731g_CP0_modem_sc7731g_mod em UserData : STATE : DAMAGED - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:01:26 Operation : Format FS / Reset Settings [ v2.09 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731x_BASE : SC7731GEA_eMMC_1GB_NS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:01:00 Operation : Read FW [ v2.09 ] Extra : Ignore CriticalPart Verify : Enabled 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731x_BASE : SC7731GEA_eMMC_1GB_NS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! >>> Error : Device NOT INITIALIZED ! Initialize it first via "IDENTIFY" ! >>> Make sure you have made "IDENTIFY" first! Reconnect Power/Cable! Operation : Read FW [ v2.09 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... >>> Device not found! >>> Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.09 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731x_BASE : SC7731GEA_eMMC_1GB_NS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Device info : Patch Level : MRA58K Display ID : Series_A_A9_Android_8.1_V01_2020-07-27 Ver. Incmt : root-103233 Ver. CodeName : REL Ver. Release : 8.1 Sec. Patch : 2019-12-01 Build Time : 27.07.2020 Product Brand : Series A Product Name : A9 Product Device : A9 Product Board : sp7731gea_hdr Product Manfct : Series A Board Platform : sc8830 Product Info : A9 Product Model : A9 Platform Version: MOCORTM_14B_MP_7731G_W17.22.4_Debug Project Version: sc7731g_CP0_modem BASE Version: TM_BASE_W17.22.4 MMI Version: sc7731g_modem HW Version: sc7731g_CP0_modem CMP_Time : 05-31-2017 21:23:59 MODEM TAG : MOCORTM_14B_MP_7731G_W17.22.4_Debug_TM_BASE_W17.22 .4_sc7731g_CP0_modem_sc7731g_CP0_modem_sc7731g_mod em - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:01:28 Operation : Read FW [ v2.09 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731x_BASE : SC7731GEA_eMMC_1GB_NS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Device info : Patch Level : MRA58K Display ID : Series_A_A9_Android_8.1_V01_2020-07-27 Ver. Incmt : root-103233 Ver. CodeName : REL Ver. Release : 8.1 Sec. Patch : 2019-12-01 Build Time : 27.07.2020 Product Brand : Series A Product Name : A9 Product Device : A9 Product Board : sp7731gea_hdr Product Manfct : Series A Board Platform : sc8830 Product Info : A9 Product Model : A9 AndroidVer : 8 VlnrLevel : 0x01 SC8830__Series_A__A9__8.1__Series_A_A9_Android_8.1 _V01_2020-07-27__MRA58K__A9 Read : prodnv.img ExtSparse : Compression ratio : 45% Read : phase.cfg Read : wmodem.bin Read : wdsp.bin Read : wnvitem.bin Read : modem_wcn.img Read : wcnnvitem.bin Read : boot_logo.bmp Read : fastboot_logo.bmp Read : logo2.bin Read : logo3.bin Read : logo4.bin Read : logo5.bin Read : boot.img Read : system.img ExtSparse : Compression ratio : 88% Make : persist.img Read : sysinfo.bin ExtSparse : Compression ratio : 4% Make : cache.img Read : recovery.img Make : userdata.img Read : u-boot.bin Read : u-boot-spl.bin Firmware size : 0x4D1AD380 ( 1,20 GiB ) Android Info saved : _Android_info.txt Reconnect Power/Cable! Done! Elapsed: 00:08:59 |
The Following 3 Users Say Thank You to leroi2018 For This Useful Post: |
11-18-2020, 02:38 | #9 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
As a result you should download 500 Mb only instead of 1,2 Gb Do you have any info about archive software and methods ? | |
11-21-2020, 22:51 | #10 (permalink) |
Member: 2809120 Status: Offline Thanks Meter: 83 | sorry invens A9 firmware share on support Operation: Upload File: E:\1-infinity\Infinity firmware\Invens A9@ leroi2018 SC8830__Series_A__A9__8.1__Series_A_A9_Android_8.1 _V01_2020-07-27__MRA58K__A9.7z Authentication... Initialization... 21/11/2020: 22:45:00: Upload file 540,11 Mb 21/11/2020: 22:45:04: Uploading 540,11 Mb... 21/11/2020: 22:49:19: Finished |
12-02-2020, 17:26 | #11 (permalink) |
Insane Poster Join Date: Aug 2011 Location: United States
Member: 1629444 Status: Offline Thanks Meter: 47 | file worked for me 100% invens A10 Card found : ******** , v0145 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.07 Load IDBase v8331 Ok! Open : SPD_PROG.xml Reading package ... Read package finished! Created by Infinity-Box (c) 2020 Chinese Miracle II : Spreadtrum / UniSoc Service Module Device Info file : _Android_info.txt Patch Level : MRA58K Display ID : Series_A_A10_Android_8.1_V01_2020-05-22 Ver. Incmt : root-103233 Ver. CodeName : REL Ver. Release : 8.1 Sec. Patch : 2019-12-01 Build Time : 22.05.2020 Product Brand : Series A Product Name : A10 Product Device : A10 Product Board : sp7731gea_hdr Product Manfct : Series A Board Platform : sc8830 Product Info : A10 Product Model : A10 SECSolution : LEGACY [SS] Operation : Flash Firmware [ v2.07 ] Setting : Update NVRAM : False Setting : Force NVRAM : False Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : INFINITY FW PACKAGE Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! PMTMng : Load PMT PMTMng : 0x20 PMTMng : Update PMT Ok! FSIMG : prodnv.img CODE : wmodem.bin CODE : wdsp.bin CODE : modem_wcn.img CODE : boot_logo.bmp CODE : fastboot_logo.bmp CODE : logo2.bin CODE : logo3.bin CODE : logo4.bin CODE : logo5.bin CODE : boot.img FSIMG : system.img FSIMG : persist.img FSIMG : sysinfo.bin FSIMG : cache.img CODE : recovery.img FSIMG : userdata.img UBOOT : u-boot.bin UBOOT : u-boot-spl.bin ERASE : WFLASH ERASE : WCNFLASH ERASE : MISC Flashing finished! Reconnect Power/Cable! Done! Elapsed: 00:06:15 |
The Following User Says Thank You to BBoyGSM For This Useful Post: |
12-03-2020, 15:49 | #12 (permalink) | |
Member: 2809120 Status: Offline Thanks Meter: 83 | Quote:
please i just lost my Hard disk and all so please i need this invens A10 file on sharefile link , our infinity server is so slow and got error due internet connexion so need to wait tommorrow so late for so please send my just link or others people can help customer is waiting it is etrange but this is life and this is why i share for free this kind of file . thanks for your prompt reply leroi | |
