Old 11-21-2017, 08:01   #1 (permalink)
Member: 1826863
Thanks Meter: 32
oppo f1s 1601 network unlock fail any solution?
[AP] : Initial info read Ok!
Brand : OPPO
ProdName : A1601
ProdModel : A1601
Device : A1601
AndroidVer: 5.1
MTKxCPU : MT6755
MTKxPRJ : A1601EX_11_A.27_170111
SECURITY :
IMEI_SW [1] : 863897035143481
IMEI_SW [2] : 863897035143481
BTMAC Addr : E447907C2C44
WiFi MAC : E447907C2C44
EXTRA :
LCD : Not info available
LCD Res : M_HEIGHT=1280xM_WIDTH=720
TOUCH [0] : STOM_KERNEL_TOUCHPANEL=GT1XX
CAM [0] : STOM_HAL_IMGSENSOR=s5k3l8_mipi_raw
CAM [1] : imx258_mipi_raw
CAM [2] : ov8865_mipi_raw
CAM [3] : s5k3p3sp_mipi_raw
MODEM : oppo6750_15331_lwg
Done!
Elapsed: 00:00:18
Reconnect Power/Cable!
Wait for phone...
Phone found! [ 83 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x01000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
BootLdrSS : SIGNED with SPRELOADER
Processing DA stage
Sending and initialize DA ...
DAgent configured successfully
Connection agent : BROM
DRAM configured from ScatFW!
Link with DAgent established
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x13 , OEM : 014E
[eMMC] : FLASH_INF : [NOT_IN_BASE] , V79J3
[eMMC] : FLASH_CID : 13014E51334A3937561003C4D33AC343
[eMMC] : FLASH_LEN : 0x0000000747C00000
[eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB]
DEV RID : 0xD1A8AC4F70BC8487FB8C7680591EFCDA
INT RAM : 0x00000000
EXT RAM : 0x80000000 [2 GiB]
[NAND] : FLASH : NOT INSTALLED
[UFSM] : FLASH : NOT INSTALLED
[HSUSB] : MODE : FULL-SPEED
Boot Ok!
USBDL : Init HSUSB Ok
Slot[1] SIMLock Info :
[1] Level , [Locked] : True , [Count] : 5 , [Spc] : 512 , [UnlockCode] : 12345678
[2] Level , [Locked] : False
[3] Level , [Locked] : False
[4] Level , [Locked] : False
[5] Level , [Locked] : False
[6] Level , [Locked] : False
[7] Level , [Locked] : False
Slot[2] SIMLock Info :
======== Info
If phone not asking code :
1. Open MTK Setting Menu : *#*#3646633#*#*
2. GoTo : SimMELock->Network->Personalization->Unlock
3. Enter code
If Code not accepted - use "SP Direct Unlock" mode
Done!
Elapsed: 00:00:26
Wait for phone...
Phone found! [ 83 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
Boot Ok!
SIM Lock Status : Locked!
Unlocking now ...
Error while unlocking, somethig went wrong!
Operation Failed
Elapsed: 00:00:41
Old 11-21-2017, 08:03   #2 (permalink)
Member: 1826863
Thanks Meter: 32
this option hide SimMELock ????????
Old 11-21-2017, 08:09   #3 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,790
use code search google,cm2 not supported
Page generated in 0.14019 seconds with 9 queries
