10-04-2011, 21:04 | #1 (permalink) |
No Life Poster Join Date: Mar 2002 Location: Europe, Lemberstadt Age: 53
Member: 9889 Status: Offline Thanks Meter: 50 | Iphone 3g problem i made fullflash backup but after this phone dont power! i try format but prog cant do it CPU 6235 read: COM9 [VCP0] selected module v4.01 Device: _Autodetect MT6228-6268 NAND Checking data, wait... Action: read flash NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8B00:8A00 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[001E]: 0020:007600200076 [ST] ST512W3A chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (921600)... done interesting cpu type found: 6235:8B00:8A00 ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... detect sec ro... detect custom parameters... detect project-id... detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: incorrect nand header: 5A5A5A5A5A5A5A5A5A5A5A5A5A5A5A5A warning: can not detect header nfi area detection (0 cores) finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done area size: 64Mb number of areas/bytes to read: 1:04000000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... file saved: D:\11111\00\mm\_fullflash_20111004-225736.B4M.bin Disconnect... done Finished, time used: 25 min 24 sec Remove/Install battery now ! format: COM9 [VCP0] selected module v4.01 Device: _Autodetect MT6228-6268 NAND Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8B00:8A00 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[001E]: 0020:007600200076 [ST] ST512W3A chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (921600)... done interesting cpu type found: 6235:8B00:8A00 ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... detect sec ro... detect custom parameters... detect project-id... detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: incorrect nand header: 5A5A5A5A5A5A5A5A5A5A5A5A5A5A5A5A warning: can not detect header nfi area detection (0 cores) finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done warning: can not format: HW_STORAGE_NOR is not present Format... autodetection mode... error: can not format: 0BFA:S_DA_HANDSET_FAT_INFO_NOT_FOUND Format... autodetection mode... error: can not format: 0BFA:S_DA_HANDSET_FAT_INFO_NOT_FOUND error: last error: 0BFA:S_DA_HANDSET_FAT_INFO_NOT_FOUND Disconnect... done Finished, time used: 41 sec Remove/Install battery now ! i reheat CPU and flash but nothing any idea to reviwe it? Thanx |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
6110 5.47 sw unlock problem | gsms | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-1999 19:43 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
