Old 03-05-2011, 15:12   #1 (permalink)
Member: 764950
iphone 4g clone read write problem
i have backup from original workinng phone..
i wrote it another phone...
now that phone cannot power on
i backuped original good working phone with chinese miracle v3.27
with page+spare option
here is the log...
COM9 [VCP0] selected
module v3.27
Device: Autodetect 6228-6253 NAND
Checking data, wait...
Action: write flash NAND
write: Firmware
V101_PCB01_GPRS_MT6235B_S01.X7_101213_V1_4_QC_SET_ FOR10.BIN_FLNHYG0UGG0MF1P_5SH0E__fullflash_2011030 5-214030.B4M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
nfi area detection...
converting data...
done 0x07C1F200 bytes
bootloader version: V101_BOOTLOADER_V005_MT6235B_X7_101213_V1_4_QC_SET _FOR10.bin
nfi area detection (3 cores) finished: Ok
"format ffs" active
interface: BROM_DLL_v3.1016.00
Connect...
Connecting...
Booting...
Release Power button now !
bootcode current/expected: 3.2/3.2
CPU: 6235:8A04:8A01
status: FF
bbchip bl ver: FE
NOR flash chip: not installed
NAND flash id[0018]: 00AD:007900A50000 [HYNIX] HY27XA081G1M
chip size: 128Mb
page/spare size: 0200/0010
pages per block: 0020
bits i/o: 08
address cycles: 04
internal RAM size: 00010000
external RAM: S_DA_RAM_ERROR
done
Set baudrate (921600)...
done
ram test...
testing...
ram test passed
===> detect existing firmware structure...
detect ffs...
ffs offset/size: 03400000/04C00000
firmware size: 52Mb
ffs size: 76Mb
detect sec ro...
detect custom parameters...
detect project-id...
project-id: X7_101213_V1.4_QC_SET_FOR10
detect NAND info...
number of areas/bytes to read: 1:00034000
reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)...
warning: ffs can not be detected
TCL-ID detection...
TCL-ID detection done
startup code area #1 detection...
number of areas/bytes to read: 1:00004000
error: unexpected answer:
startup code area #1 is invalid
startup code area #1 detection done
rom info ver: 07
sw version: V101_PCB01_GPRS_MT6235B_S01.X7_101213_V1_4_QC_SET_ FOR10.BIN_FLNHYG0UGG0MF1P_5SH0E
project-id: X7_101213_V1.4_QC_SET_FOR10, 71F9FB49
code offset: 00000000
rom info structure: [protected] type (07), 1 record(s)
TCL-ID is absent
===> done
converting data...
startup code area #1 check...
rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.00006235.[V101_PCB01_GPRS_MT6235B_S01.X7_101213_V1_4_QC_SET_ FOR10.BIN_FLNHYG0UGG0MF1P_5SH0E_49FBF971].rpl
rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.00006235._V101 _PCB01_GPRS_MT6235B_S01.X7_101213_V1_4_QC_SET_FOR1 0.BIN_FLNHYG0UGG0MF1P_5SH0E_49FBF971_.rpl
rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.00006235.[V101_PCB01_GPRS_MT6235B_S01.X7_101213_V1_4_QC_SET_ FOR10.BIN_FLNHYG0UGG0MF1P_5SH0E_49FBF971].rpl
rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.00006235._V101_PCB01_GPRS_MT6235B_S01.X7_101213_ V1_4_QC_SET_FOR10.BIN_FLNHYG0UGG0MF1P_5SH0E_49FBF9 71_.rpl
warning: unknown firmware: V101_PCB01_GPRS_MT6235B_S01.X7_101213_V1_4_QC_SET_ FOR10.BIN_FLNHYG0UGG0MF1P_5SH0E_49FBF971
Unknown firmware found (v.3.27, database date: 27.02.2011), user action required:
1. download latest software from support area and try again
2. if no still luck follow the next procedure:
- find good working phone with the same firmware:
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
- be little bit patient and wait update
error: startup code area #1 can't be fixed
You can flash phone now but can not finalize it,
in most cases phone CAN NOT power-on.
Do you want to continue anyway ?
number of cores: 3
loading files...
number of areas: 3
done
write...
write bootloader...
write core...
warning: can not format: HW_STORAGE_NOR is not present
Format...
Disconnect...
done
Finished, time used: 16 min 3 sec
Remove/Install battery now !
please help
Old 03-05-2011, 21:17   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
please upload firmware which was read from good working phone
use rapidshare.com or 4shared.com
Eeprom reading KLImax Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 09-22-2011 15:55
GId1 problem old_man Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 10-18-2006 15:21
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Page generated in 0.15063 seconds with 10 queries
