iphone 6 clone Operation : Check / Read Info [ v1.43 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital Boot Ok! BB_CPU_PID : 6571 BB_CPU_NME : [MediaTek] MT6571_S00 BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8B NAND Flash : 00EC00BC00000066005600EC00BC0000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader NAND FlashIC initialized [NAND] : FLASH_VEN : 0x008D , [SAMSUNG] KA100O015E_BJTT/KF94G16Q4V [NAND] : FLASH_DIE : 00EC 00BC 0000 0066 0056 00EC 00BC [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/00/NIM_Px-1 DEV RID : 55EB7613675FA44FF8370EC6035E25CD INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Info read not done :( Erased phone or unsupported FlashIc? You can change settings : Settings -> Other -> NAND init Mode Done! Elapsed: 00:00:09 Reconnect Power/Cable! how to solve this, the phone blink only on the logo |
Change Setting -> Sp Other -> Nand Init Mode P-1 - P2 |
probleme solved i selected p3.1 Operation : Check / Read Info [ v1.43 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital Boot Ok! BB_CPU_PID : 6571 BB_CPU_NME : [MediaTek] MT6571_S00 BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8B NAND Flash : 00EC00BC00000066005600EC00BC0000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader NAND FlashIC initialized [NAND] : FLASH_VEN : 0x008D , [SAMSUNG] KA100O015E_BJTT/KF94G16Q4V [NAND] : FLASH_DIE : 00EC 00BC 0000 0066 0056 00EC 00BC [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/01/NIM_Px-1 DEV RID : 55EB7613675FA44FF8370EC6035E25CD INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : alps ProdName : benrui71_e_lca ProdModel : MT6571 Device : benrui71_e_lca AndroidVer: 4.2.2 MTKxCPU : MT6571 MTKxPRJ : ALPS.JB7.MP.V1.14 Done! Elapsed: 00:00:23 Reconnect Power/Cable! Operation : Format FileSystem [ v1.43 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital Boot Ok! BB_CPU_PID : 6571 BB_CPU_NME : [MediaTek] MT6571_S00 BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8B NAND Flash : 00EC00BC00000066005600EC00BC0000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader NAND FlashIC initialized [NAND] : FLASH_VEN : 0x008D , [SAMSUNG] KA100O015E_BJTT/KF94G16Q4V [NAND] : FLASH_DIE : 00EC 00BC 0000 0066 0056 00EC 00BC [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/01/NIM_Px-1 DEV RID : 55EB7613675FA44FF8370EC6035E25CD INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:15 Reconnect Power/Cable! |
Thanks |
