10-22-2016, 12:31 | #1 (permalink) | |
Product Manager Join Date: Apr 2008 Location: Whitehole throught Blackhole!
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | Lave iris X1 Atom flashing fail while Og tool done. What is problem here? Quote:
Original Tool Done within few minute but CM not. Cm stuck at 99%. wasted much more time. What is the Solution team? BR Dipendra Pathak | |
The Following User Says Thank You to Dipendra Pathak For This Useful Post: |
10-22-2016, 12:59 | #3 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | All firmware of the following link tested, all fail should be all files bad ? Lava Iris X1 Atom Stock Firmware ROM (Flash File) If you try with OG tool will be success!!! BR Dipendra Pathak |
10-22-2016, 13:00 | #4 (permalink) |
No Life Poster Join Date: Sep 2006 Location: ---> Hope
Member: 355782 Status: Offline Thanks Meter: 1,265 | another user wasted 02:42 time too Code: Phone found! [ 16 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! [FL] : Enabled NVM update. Will program all NVM images found in FW ! PMTManager : Load 0x18 records PMTManager : PMT Update Ok! Flashing now [FlashProc] : NVM Update Current ID : NV_W Current Part : wfixnv1 [FlashProc] : Ok! [FlashProc] : NVM Update Current ID : NV_WCN Current Part : wcnfixnv1 [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEUBOOT Current Part : uboot [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : SPLLOADER Current File : u-boot-spl-16k.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_W Current File : SC7702_sc7731g_band128.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : DSP_W Current File : DSP_DM_G2.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_WCN Current File : SC8800G_x30g_wcn_dts_modem.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOT Current File : boot.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : RECOVERY Current File : recovery.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : SYSTEM Current File : system.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : USERDATA Current File : userdata.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOTLOGO Current File : LOGO.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : FASTBOOT_LOGO Current File : LOGO.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH Current Part : wruntimenv1 [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH_WCN Current Part : wcnruntimenv1 [FlashProc] : Ok! [FlashProc] : CODE Current ID : PRODNV Current File : prodnv.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : CACHE Current File : cache.img Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEMISC Current Part : misc [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASESD Current Part : internalsd [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : UBOOTLOADER Current File : u-boot.bin Flashing now ... [FlashProc] : Ok! Elapsed: 00:02:42 Reconnect Power/Cable! |
10-22-2016, 13:13 | #5 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | Another Smart User is here. perhaps you did not see error code! And hope you won't understand too. Just you can show screen short :P Can you describe error code meaning? Let the coder find it. And I told you i did it with OG tool? Let the coder do it. BR Dipendra Patha |
10-22-2016, 13:20 | #6 (permalink) |
Member: 355782 Status: Offline Thanks Meter: 1,265 | did I wrote something wrong ? maybe you are thinking I just made this fake post against you. I m a simple user like you so I am in your line so dont worry. I just made my day looking some interesting posts like below dont forget to see date. http://forum.gsmhosting.com/vbb/11661610-post10647.html in last nothing concern to you these are just for coders to compare error codes. |
The Following User Says Thank You to Nasir Mobiles For This Useful Post: |
10-22-2016, 13:59 | #7 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | I did not tell you that you have posted fake. Every user posts good from his site but the view of team might be different! We should not forget here one thing. After flashing mobile was killed by CM tool. Previously, it was ON and Phones used to come and goes but after flashing device got dead. That's why I am here BR Dipendra Pathak |
10-24-2016, 05:06 | #11 (permalink) | ||
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | Quote:
Thanks BR Dipendra Pathak | ||
10-24-2016, 06:23 | #12 (permalink) | |
Freak Poster Join Date: Jun 2012 Location: bali
Member: 1778254 Status: Offline Sonork: sornork id Thanks Meter: 36 | Quote:
10-24-2016, 10:52 | #14 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
possible repair process was: you have got a damaged phone, you have tried to use CM, it make almost all work (clear memory fault etc.) and then stuck at final flashing phase. then you use factory file/flasher for final flash phase and phone become ok with help of both software. good result is - user is happy. | |
10-25-2016, 15:23 | #15 (permalink) |
No Life Poster Join Date: Sep 2009 Location: Hello Online Service
Member: 1126941 Status: Offline Sonork: 100.1672154 Thanks Meter: 2,488 | kindly try with flash erase then flash again.. i made 2-3 mobile after this error show yes ..i also get this error in some spd 7731 but..after full erase...select update nv option...then flash again hope u will get good result |
